Author Topic: 1.6 na crank bolt torque  (Read 8133 times)
December 20, 2008, 06:14:47 am
  • 1739
« on: December 20, 2008, 06:14:47 am »
I don't have a bentley for the mk1 or 2 's so can someone tell me the torque spec for the crank pulley bolt. Thanks
Reply #1December 20, 2008, 06:21:36 am
« Reply #1 on: December 20, 2008, 06:21:36 am »
If it is replaced or the newer one it is a TTY stretch type and only supposed to be used 1 time. Older one I forget, but I was thinking alot of guys here do 242 loctite and run it in with an impact.
The TTY bolt I believe was something like 140 FT LBs plus a 1/4 turn.
Reply #2December 20, 2008, 06:22:54 am
« Reply #2 on: December 20, 2008, 06:22:54 am »
crankshaft sprocket to crankshaft (lubricated)
6-sided bolt with washer 137
head head bolt with washer 111
12 sided bolt with collar 44 + 1/4 turn
Those are foot pounds
Reply #3December 20, 2008, 06:25:08 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: December 20, 2008, 06:25:08 am »
Bentley for 85-92:
Crankshaft sprocket to crankshaft (lubricated)
     6 sided bolt with washer                    180 Nm  (137 ft. lb.)
     Hex head bolt with washer                 150 Nm  (111 ft. lb.)
     12 sided bolt with collar (no washer     90 Nm   (66 ft. lb.) + 1/2 turn (180 deg.)
Edit: Obviously I type slower than Tyler :)
Calvin
91 VW Golf 1.6NA 5spd
Reply #4December 20, 2008, 08:10:17 am
  • 1739
« Reply #4 on: December 20, 2008, 08:10:17 am »
Okay thanks y'all. I used to just do it some locktite and the impact gun, but since the whole 1.9 crank fiasco, i figure it's better to do it right. VW cranks are not industrucible !
Reply #5December 21, 2008, 07:34:04 am
« Reply #5 on: December 21, 2008, 07:34:04 am »
Quote from: "burn_your_money"
Quote from: "clbanman"
Bentley for 85-92:
C
I wish Bentley Publishers knew what they were doing. I was also using my 85-92 Bentley
Reply #6December 21, 2008, 08:06:44 am
  • 1739
« Reply #6 on: December 21, 2008, 08:06:44 am »
Just for anyone who cares: we locktite'd [?] the bolt and pulley inset, torqued it to 66 ft/lbs, really didn't seem to want more than that,  and  then just tried to give it 1/4-1/2 turn. It went about 1/3 rd of a turn. Should be fine.
Reply #7December 21, 2008, 09:49:52 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #7 on: December 21, 2008, 09:49:52 am »
I was wondering about that.  I was using data from section 3 page 44. section 8 Engine technical data.  Mine seems to have been printed about 3/92.
Calvin
