Author Topic: Tranny Swap, opinions please  (Read 7913 times)
Reply #30December 08, 2008, 12:07:39 pm
« Reply #30 on: December 08, 2008, 12:07:39 pm »
Quote from: "theman53"
http://www.ryanrupp.com/album/webpics/02Aswap.pdf
I want to do this someday...maybe you can tell me how it goes :D
Linky no workie..  :(
Reply #31December 08, 2008, 03:12:12 pm
« Reply #31 on: December 08, 2008, 03:12:12 pm »
Dang!
That was the link that showed pretty much a step by step install of an 02A six speed manual swap into a much older chasis. I don't have anyother link to it. Maybe in a couple years I will do it anyway and show it then  :lol:
Reply #32December 08, 2008, 04:22:28 pm
« Reply #32 on: December 08, 2008, 04:22:28 pm »
Quote from: "Quantum TD"
Bad idea here. If grunt is what you want, I'd say try to find an AVX and swap in a .71 5th. That will give you plenty of grunt around town, and an overdrive 5th on the highway. The 4.25 R&P really keeps power at the pedal.
The AWY and the 4K are essentially the same trans, and you'll be out of gears by the time you hit 55-60 MPH. That's not a good idea for motor longevity.
with the 4K at 60-65 Mph the engine will sit at a very comfortable 3100-3350 RPM.. and thats before my plans to swap a .75 in to it..
4K-> 3.94    3.45    2.12    1.44    1.13    0.89
I will be able to use each bit of all the four gears around town and even cruise around in 5th. Sure the AVX would be much better for the REAL grunt.
AVX->      4.25    3.45    1.94    1.29    0.91    0.75
This trans.. at the same speed only lowers the rpm 300.. and in all the other gears the difference in speeds between the two trans (AVX and 4K) is next to none (+- 4-5). Not to mention i've never heard of anyone using an AVX lol..
Reply #33December 08, 2008, 11:34:57 pm
Quantum TD
  • 1195
« Reply #33 on: December 08, 2008, 11:34:57 pm »
Quote from: "8v-of-fury"
True about the RPMS difference, but 3300 is not very 'comfortable' for a motor with a 4500 max RPM.You're still in the power band, looking for another gear at 3300 RPMS. 300 RPMs is a big difference when you're talking about winding out at 57 MPH vs. 65 MPH. It's all relative, I understand. I don't need a tach to tell me that my motor is straining and killing my MPG. So, when I hit 55 and the motor is screaming with a 4k/2h, I'm not really gonna push the envelope to see how long my car can withstand that kind of torture.
One of my recent cars was a 1991 Jetta Coupe with an AWY. I drove it from CT to TN. I never went past 65 MPH, cos' the motor was begging for mercy.
As for the .75 swap: yes, you'll be able to bang thru the gears around town, but look at the 4th to 5th change when you compare the AVX to the 4k. It would almost be like shifting from 3rd to 5th in the AVX, if you were to put a .75 in your 4K.
It's all about what you want out of your car. If you want to roast Ricers with fart cans, then put on the AWY or the 4K and get 36-39 MPG. If you swap in the .75 and do a lot of highway drving, then you'll improve that number.
If you want to drive like most 'normal' people, and get 45-55 MPG, then go with the 'good' transmissions (AOP, AGS, ACH, 7A). If you think you can have the best of both worlds, then try the .71 or .75 5th swap on a low-geared trans.
I'm not preachin', just giving my own real-world experience. Obviously, if you have a 1.6NA, the ideal would be a 4k/AWY with a 6th gear. Not all can afford that luxury, or are willing to swap in an 02A just for a 1.6NA, so we're left with what was produced. Might as well make the best of a less-than-ideal situation.
Reply #34December 09, 2008, 08:03:35 am
overdrivegear
  • 120
« Reply #34 on: December 09, 2008, 08:03:35 am »
FF, FO, FN: These are a nice fit for the 1.6NA (3.89 R&P and .71 or .75 5th). Unfotunately (as some note), they won't fit into a MK2 or later. The gearing on these is really well-suited for both 1.6 NA and TD applications.
Why can't you put an FF in a MK2 car?  What have people said about that?
I have a new project 85 Golf with the ACH and I want to put in the FF from my 81 rabbit...or would it be better to take the .71 fifth from the FF and put it on the ACH for the 7A 'CLONE'?
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #35December 09, 2008, 08:21:28 am
« Reply #35 on: December 09, 2008, 08:21:28 am »
The FF has a different rear mount. There are no boss's for the mk2 rear mount to attach to.
Reply #36December 09, 2008, 09:06:16 am
arb
« Reply #36 on: December 09, 2008, 09:06:16 am »
If you want to use a FF like I am, you could make your own mounts like I am.
Reply #37December 09, 2008, 10:08:59 am
« Reply #37 on: December 09, 2008, 10:08:59 am »
Quote from: "arb"
I almost did that then I discovered there are 2 different FF's and I wasn't sure which one I had so I did the ACN instead.
I still haven't looked to confirm which one I actually have. Maybe tonight.
Reply #38December 09, 2008, 10:31:10 am
arb
« Reply #38 on: December 09, 2008, 10:31:10 am »
Quote from: "zukgod1"
What ? 2 different FF's ?  Interesting. Mine has the differential mount facing the passenger side - it is bolted to the housing with 2 studs. If it wasn't snowing last night and rain/snow tonight, I've have photos already...
Reply #39December 09, 2008, 10:50:56 am
« Reply #39 on: December 09, 2008, 10:50:56 am »
FN, FF, FH (most to 7/80) .76 5th gear
FN, FF, FH, FJ (most from '81) .71 5th gear
Both have the same R&P
Reply #40December 09, 2008, 11:00:12 am
arb
« Reply #40 on: December 09, 2008, 11:00:12 am »
I remember reading that now.... thanks ! I don't know what year my tranny is - the engine is an 82.5 so maybe I have the taller overdrive.
Reply #41December 09, 2008, 11:49:31 am
« Reply #41 on: December 09, 2008, 11:49:31 am »
I'm hoping mine is the taller one so I can take the 5th .71 out and toss it in my AWY.
Reply #42December 09, 2008, 03:10:23 pm
« Reply #42 on: December 09, 2008, 03:10:23 pm »
Yes ideally the best would be a 4K with a 6th gear :P I didn't mean to sound offended or lippy but you are right i am making the best of a less than ideal situation. I wish to maintain the quickness around town and with the .75 or .71 that jump from 4th to 5th gear will be a little sacrifice to pay for being able to have the best of both worlds.
Also for now (before the 5th gear swap) at around 3050-3150 rpm, 60-65 mph is just fine for me highway wise.. AND i will still be able to use 5th around town :P
If im swapping in an N/a im expecting to be a little slower.. besides why do i need a reason to speed? if the car won't go that fast i will never get a ticket.. lol
all about the mindset :P Maybe one day.. i will have one of the 'good' trans mated to a TD for optimum performance :P
