Author Topic: ~Mechanical 1.6td Custom built MLS head gaskets!!!~  (Read 20198 times)
Reply #45January 05, 2009, 10:52:55 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« Reply #45 on: January 05, 2009, 10:52:55 am »
Edit: could be little of topic...but.
I´ve reused several of my 1.9 headgaskets and I´m still running 30-35 psi of boost afterwards. And I must say it works great!  :D
A experienced friend of mine which builds race engines told me to stop buying new expensive headgaskets when all he did (if the gasket wasn´t totally screwed up) was putting a thin layer of spraypaint on each side to fill in the small scratches etc.
I always use new headbolts each time when putting it all back together again.
Don´t hate on me for doing it before trying it out yourself. It works!  :twisted:
<-- My M-tdi Mazda B-1800 and my other cars
Reply #46January 05, 2009, 01:35:54 pm
  • 3468
    • McScrubbins Body Wash
« Reply #46 on: January 05, 2009, 01:35:54 pm »
that's awesome! definitely trying that now i have studs!
Reply #47May 22, 2009, 07:42:02 am
lovinthedeez
  • 489
Re: ~Mechanical 1.6td Custom built MLS head gaskets!!!~
« Reply #47 on: May 22, 2009, 07:42:02 am »
i love mcmaster-carr.  the website though, can be tough navigating it sometimes.  so you use viton to plug up the head, huh? any pics?
you guys think viton is ever going to be less than 15 dollars a foot? ;D
Reply #48May 22, 2009, 09:31:32 am
saurkraut
  • 904
« Reply #48 on: May 22, 2009, 09:31:32 am »
I tried Viton sheet to plug the extra oil drain hole.  The durometer of the viton was too high so the head wouldn't seat fully.  The best/cheap solution is to use a section of a brand new oil cap gasket.  It allot softer, is oil/heat resistant, and readily available.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
