Author Topic: Special Socket for removing turbo?  (Read 1885 times)
November 16, 2008, 12:26:12 pm
allsierra123
« on: November 16, 2008, 12:26:12 pm »
Cant seem to find a socket to fit it without slipping? What size is it?
Reply #1November 16, 2008, 12:38:36 pm
allsierra123
« Reply #1 on: November 16, 2008, 12:38:36 pm »
ok It didnt look like a 12 point to me. Had a brain freeze I guess its cold out there. While I have it off how hard is it to freshen up with one of those rebuild kits? Its the K03
Reply #2November 16, 2008, 03:57:18 pm
« Reply #2 on: November 16, 2008, 03:57:18 pm »
You need to use a 3/8" socket or a cut down 1/2" one for the inner most bolts.
If you do decide to freshen up the turbo, check the shaft for wear. KO3s are known for dying.
Reply #3November 16, 2008, 04:19:11 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: November 16, 2008, 04:19:11 pm »
or an offset 12mm 12pt. box end wrench works fine too.
