Author Topic: engine rebuild questions PLEASE help.  (Read 3130 times)
November 15, 2008, 10:46:10 am
ObscuredByClouds
  • 98
« on: November 15, 2008, 10:46:10 am »
Are the con rod bolts TTY? I have an 86 1.6td
Regardless, what is the torque spec?
Is the maximum ring gap wear 1.00mm?
Reply #1November 15, 2008, 10:53:36 am
rallydiesel
  • 1880
« Reply #1 on: November 15, 2008, 10:53:36 am »
Yes, they are TTY. The torque spec is 22 lbs. ft. plus a quarter turn. Max ring gap of any ring is 1.00 mm.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2November 15, 2008, 11:20:27 am
monomer
  • 414
« Reply #2 on: November 15, 2008, 11:20:27 am »
Quote from: "NoSurrenderAG"
excellent thanks. Could anyone point me in a direction to get them? Does prothe have them?
bolts or rings?
I went ARP for the bolts, ordered from www.headbolts.com
www.michiganvw.org
Reply #3November 15, 2008, 12:52:11 pm
blkboostedtruck
  • 1535
« Reply #3 on: November 15, 2008, 12:52:11 pm »
I also have 76.50 rings, my pistons have 76.48 stamped on them.. does that mean my rings are wrong?
sound right! did you put a ring in a cylinder and check the gap?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4November 15, 2008, 01:02:27 pm
« Reply #4 on: November 15, 2008, 01:02:27 pm »
Call the dealer and get stock bolts. I think they are $2-$5 a piece
Reply #5November 15, 2008, 01:26:21 pm
« Reply #5 on: November 15, 2008, 01:26:21 pm »
Don't forget to hone the block if you are installing new rings
Reply #6November 16, 2008, 01:26:25 pm
« Reply #6 on: November 16, 2008, 01:26:25 pm »
need more help on day 2.
Are the crankshaft & iShaft pulley bolts TTY?
Crankshaft yes, intermediate shaft no, camshaft no.
Reply #7November 16, 2008, 01:44:44 pm
rallydiesel
  • 1880
« Reply #7 on: November 16, 2008, 01:44:44 pm »
Quote from: "Vincent Waldon"
There are some crankshaft bolts that are not TTY although I don't think they stock them anymore. The non-TTY crank bolts look like regular hex bolts with a big washer, while the newer style TTY are 12-sided bolts.
Reply #8November 16, 2008, 01:55:51 pm
« Reply #8 on: November 16, 2008, 01:55:51 pm »
i think the early 1.6NA bolts 81-83 maybe? are re-useable... but not sure!
Reply #9November 16, 2008, 02:35:49 pm
rallydiesel
  • 1880
« Reply #9 on: November 16, 2008, 02:35:49 pm »
My 91 TD has a non-TTY crank bolt but I wouldn't recommend it cuz it has come loose before despite being torqued 30 lbs over. Luckily I caught it before disaster happened.
Reply #10November 16, 2008, 02:43:34 pm
« Reply #10 on: November 16, 2008, 02:43:34 pm »
Yup, I believe that all non-TTY crank bolts have been discontinued and the only ones you can get from the dealer are 12-point TTY.
Or so I'm told...  :wink:
Reply #11November 17, 2008, 04:39:25 pm
monomer
  • 414
« Reply #11 on: November 17, 2008, 04:39:25 pm »
Aff! You guys are heroes finding the conrod bolts for 2-5 a piece. They're $15.55 from VW.. I CAN'T pay that. Fuucking obsurd.. where can I get them cheaper?
I have a 6 point crank pulley bolt I guess I'll reuse it and see.
I think my set was $80ish...
damn ARP!
www.michiganvw.org
Reply #12November 17, 2008, 06:12:18 pm
Green79
  • 27
« Reply #12 on: November 17, 2008, 06:12:18 pm »
I just bought a 6-pt crank bolt for my '79 1.5 from the dealer... it was only 89 cents! Of course, the washer was around $6.50- kinda odd.
'79 1.5 Rabbit
