Author Topic: 1.6 injectors in an AAZ  (Read 2798 times)
November 14, 2008, 04:22:43 pm
ilikevwdiesel
  • 1202
« on: November 14, 2008, 04:22:43 pm »
Hey what's up with using 1.6 injectors in an AAZ motor, I put some in my caddy and the 1.6 injector lines wouldn't fit properly. Anyone have any tips for me? Can you even use the short injectors in an AAZ?
My Bio
Reply #1November 14, 2008, 04:39:22 pm
  • 3468
    • McScrubbins Body Wash
« Reply #1 on: November 14, 2008, 04:39:22 pm »
im going to use short 1.6 injectors in an AAZ head.
but you have to use a 1.6 pump mounting bracket and likely the pump too (unless they are the same dimensions right?)
I know that you need to keep injectors,lines and the pump mounting bracket all the same.
Reply #2November 14, 2008, 05:15:25 pm
« Reply #2 on: November 14, 2008, 05:15:25 pm »
Early Canadian B3 Passats came with essencially 1.6 injectors on the 1.9 engine. Those lines would fit perfectly. I hopefully still have a set because I will need them on my engine.
Reply #3November 14, 2008, 05:25:04 pm
ilikevwdiesel
  • 1202
« Reply #3 on: November 14, 2008, 05:25:04 pm »
Quote from: "burn_your_money"
thanks tyler, what do think I should do? I only have 1.6 TD lines and one set of 1.9 AAZ lines...I want to use 1.6 injectors, my AAZ injectors are getting craters around the pintles
My Bio
Reply #4November 14, 2008, 05:32:34 pm
ilikevwdiesel
  • 1202
« Reply #4 on: November 14, 2008, 05:32:34 pm »
Quote from: "Smokey Eddy"
so you think that on a 1.9 TD if you're using 1.6 injectors you need to use a 1.6 mount bracket, pump lines and the injectors? Is that what you mean?
My Bio
Reply #5November 14, 2008, 05:35:42 pm
gigaz2
  • 626
« Reply #5 on: November 14, 2008, 05:35:42 pm »
keep it simple, the only difference is on the pipes, 1.6 injectors=1.6 pipes
at least I had to use 1.9 piping to use a 1.9 injector on my 1.6TD, should be the same
Reply #6November 14, 2008, 05:38:51 pm
ilikevwdiesel
  • 1202
« Reply #6 on: November 14, 2008, 05:38:51 pm »
Quote from: "gigaz2"
but I put the 1.6 injectors into the 1.9 engine and the 1.6 lines didn't fit! was I hallucinating?  :?
My Bio
Reply #7November 14, 2008, 08:39:33 pm
  • 3468
« Reply #7 on: November 14, 2008, 08:39:33 pm »
Quote from: "ilikevwdiesel"
uhh yeah that's what i mean ....
*thinking*
Pretty sure you need the correct pump bracket. I read that on here somewhere.
Reply #8November 15, 2008, 08:09:12 am
« Reply #8 on: November 15, 2008, 08:09:12 am »
It won't fit. The 1.9 block is taller then the 1.6. You'll have to bend a set of lines. I'd bend whatever lines are a closer match. Why not get the 1.9 injectors rebuilt? They are suppose to give better emmisions and economy because of the dual spring.
The pump mount is irrelevant.
Reply #9November 15, 2008, 01:19:32 pm
  • 3468
« Reply #9 on: November 15, 2008, 01:19:32 pm »
Oh, ok.
I don't know why i thought you had to use the same pump mount... where did i read that...
