Author Topic: Can a tuned AAZ have about the same HP and torque output as.  (Read 11514 times)
October 28, 2008, 08:16:39 am
allsierra123
« on: October 28, 2008, 08:16:39 am »
I got into a bit of a discussion Where I was told that it was impossible to tune an aaz easily to have the same torque and HP as A tdi motor. What do you guys think?
Reply #1October 28, 2008, 11:10:33 am
allsierra123
« Reply #1 on: October 28, 2008, 11:10:33 am »
Thats what I thought. He wants dyno charts to prove it.
Reply #2October 28, 2008, 11:19:31 am
bert
  • 423
« Reply #2 on: October 28, 2008, 11:19:31 am »
T3 turbo AAZ with rover 220TD boost pin,NO OTHER MODS 75 to 112 easy  :wink:
Bert
Reply #3October 28, 2008, 11:52:35 am
molgrips
  • 134
« Reply #3 on: October 28, 2008, 11:52:35 am »
Sweet, I just got a Rover 220 boost pin :)  It's only the 70hp 1.9 AAZ engine in my car tho...
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #4October 28, 2008, 12:23:01 pm
blkboostedtruck
  • 1535
« Reply #4 on: October 28, 2008, 12:23:01 pm »
my AAZ makes a VR6 work to keep up with me! i only have a 1.6 boost pin in the pump!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5October 28, 2008, 12:52:14 pm
allsierra123
« Reply #5 on: October 28, 2008, 12:52:14 pm »
We dont have those here in the states.
Reply #6October 28, 2008, 01:00:52 pm
molgrips
  • 134
« Reply #6 on: October 28, 2008, 01:00:52 pm »
Just did the boost pin on my Passat.  Wheee!  In fact, I think I'll start a new thread about it.
Reply #7October 28, 2008, 02:59:54 pm
regcheeseman
  • 714
« Reply #7 on: October 28, 2008, 02:59:54 pm »
On standard boost?
Reply #8October 28, 2008, 03:18:01 pm
bert
  • 423
« Reply #8 on: October 28, 2008, 03:18:01 pm »
11 psi at max output on a vdo boost gauge
Bert
Reply #9October 28, 2008, 07:04:38 pm
« Reply #9 on: October 28, 2008, 07:04:38 pm »
What gear are you in for the dyno graph?
Reply #10October 28, 2008, 07:41:34 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #10 on: October 28, 2008, 07:41:34 pm »
wow, i really gotta get mine on a dyno!....
'91 Golf Cabrio 1.9TD
Reply #11October 28, 2008, 07:46:44 pm
gldgti
  • 488
« Reply #11 on: October 28, 2008, 07:46:44 pm »
Quote from: "libbybapa"
If tuned an AAZ can far surpass the HP and and torque of any of the stock 4-cyl TDI engines.
Andrew
i don't disagree, but the new 125kW 2.0TDI in the GT Sport is a formidable machine - the one i drove broke traction in 2nd gear in perfectly dry conditions, no probs... and that was on the nice sticky continental rubber, 225 section... those baby's generally just haul!
Reply #12October 29, 2008, 12:23:50 am
bert
  • 423
« Reply #12 on: October 29, 2008, 12:23:50 am »
DFW gearbox in 3rd gear
Bert
Reply #13October 29, 2008, 03:34:26 am
stewardc
« Reply #13 on: October 29, 2008, 03:34:26 am »
I have an AAZ with a ported head, a Giles pump and a T3 turbo. At 9 psi, I can easily take a TDI,and the engine is built to handle 30 psi.
Reply #14October 29, 2008, 04:43:05 am
GTD0023
  • 28
« Reply #14 on: October 29, 2008, 04:43:05 am »
Is it possible to beat a good running VR6 (170hp) ??
or even a golf G60 (160+ hp) ??
with an AAZ with these mods: 3" dp, 1.6 boost pin. T3 Turbo 20 psi, head studs fuel and pump mods....you know the usual.
IF so you would have to run under 7 sec to 60 mph.
anyone with a modded AAZ runs under 7 secs??
vw golf 1.8 16v, vw golf G60, now going diesel...
