Author Topic: '79 Rabbit L TDI  (Read 82381 times)
Reply #75October 25, 2024, 04:17:17 pm
oblique
  • 317
    Diesel while you can.
Re: '79 Rabbit L TDI
« Reply #75 on: October 25, 2024, 04:17:17 pm »
Am I the only one that cant see any pics?
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #76October 25, 2024, 06:29:31 pm
  • 2932
« Reply #76 on: October 25, 2024, 06:29:31 pm »
I don't see them either. Thought they were just taking too long to load.
 Is the brake proportioning valve the kind that's mounted in the engine bay or near the rear wheel?
Reply #77October 26, 2024, 07:07:35 am
drrtybyl
  • 146
« Reply #77 on: October 26, 2024, 07:07:35 am »
ssl enabled and should work now
near the rear wheel
yep, with a spring that pulls on the valve relative to load/stance. it had a number in the casting that didn't return any info
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
Reply #78November 11, 2024, 04:52:59 pm
oblique
  • 317
« Reply #78 on: November 11, 2024, 04:52:59 pm »
could've sworn I replied here last week.
the part number for the proportioning valve is 811614151.
Your TDI must be nice but my 1.5D is loud, slow and smokes just enough charcoal:
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #79February 08, 2025, 07:51:21 am
drrtybyl
  • 146
« Reply #79 on: February 08, 2025, 07:51:21 am »
Thanks! Your car looks good. That part number looks correct and Pelican allegedly has stock -- found some old vortex threads on this item too: https://www.vwvortex.com/threads/s1-brake-proportoning-valve-identification-rebuild.8989377/  ...apparently a Kelsey Hayes part 86652/rebuild rubber exists. It started leaking again shortly after that post so the valve is permanently? bypassed for even front/rear pressure. Not tracking or autocrossing this thing so skipping the valve doesn't seem too concerning. Seems like a lot of people delete rear brakes on these cars nowadays.
Current IP is resealed rover.
'79 Rabbit Diesel L
'96 BMW 318ti
Reply #80February 08, 2025, 07:56:43 am
drrtybyl
  • 146
« Reply #80 on: February 08, 2025, 07:56:43 am »
New goals for this car:
-Finally get AC working. The car came with the Sankyo SD-507 dealer installed system and a condenser with a large hole in it. On this dealer installed AC system , the main blower speed knob is rendered on/off only and bypassed for the aftermarket AC fan control, which implements 4 fan speeds utilizing the stock 3 speed-style resistor, while the HVAC valve is still functional. The controls still work and I'm hoping plumbing in a new drier and evaporator will hold a charge. I've got a mk3 condenser with different fittings I'll try to connect first. I've considered sourcing a new OEM condenser for ~$400
-VNT-15. Probably controlled via dawes device, which looks like the simplest solution to implement like this? This is a fully analog vehicle, so no Arduino stuff
'79 Rabbit Diesel L
'96 BMW 318ti
Reply #81February 08, 2025, 09:06:29 pm
  • 2932
« Reply #81 on: February 08, 2025, 09:06:29 pm »
Did you use the TDI alternator bracket or the alternator setup from the MK1?
I've heard that with the old sandon AC compressors you can swap the rear plate,
the one with the hoses coming off it.
 And use the rear plate from the MK1.
