Author Topic: T3 Replacement Turbo ????  (Read 6583 times)
Reply #15September 26, 2008, 02:49:11 pm
« Reply #15 on: September 26, 2008, 02:49:11 pm »
Quote from: "stewardc"
I guess I'm really looking for a "better" turbo. A ball bearing unit that spins up earlier.
Ball bearing would rock!
Reply #16September 27, 2008, 04:38:19 am
stewardc
« Reply #16 on: September 27, 2008, 04:38:19 am »
Bump --- Help !!!
Reply #17September 27, 2008, 05:36:24 am
subsonic
  • 1836
« Reply #17 on: September 27, 2008, 05:36:24 am »
Looks like you have a couple options then.  Go to something like the ko3 / k14 for faster spool. You know the deal there, more down low, less up top.  Go the VNT route with it assorted control systems. Fast response and power through the whole range.  Newer ball bearing setup, faster response but costly.   Kind of the big catch-22.  Perhaps the addition of a water / meth system would help?  Different direction, but it may achieve the results you are looking for.  Sell the IC setup and go with water / meth into the manifold.  Prices might offset each other.  Faster spool for sure, your whole loop will be like 6".  Just a thought.
Reply #18September 27, 2008, 10:31:05 am
stewardc
« Reply #18 on: September 27, 2008, 10:31:05 am »
Quote from: "subsonic"
I had a K14, don't want the troubles of a VNT. I just need the ball bearing unit, but does anyone make a direct-bolt-on for these manifolds?
Reply #19September 28, 2008, 11:50:42 am
stewardc
« Reply #19 on: September 28, 2008, 11:50:42 am »
Bumpsky
Reply #20September 29, 2008, 09:29:35 am
stewardc
« Reply #20 on: September 29, 2008, 09:29:35 am »
Quote from: "libbybapa"
I don't know of any other engines that used the trapezoidal flange except I think I saw one on a nissan once.  Short of finding one to bolt on, you could choose the one you want and make it fit.  Adapter plates aren't hard to make.  I've made quite a few with 3/8" steel, a drill press, hole saw and a power jigsaw with metal cutting blades.  Just made one yesterday for a VNT 17.
Andrew
Got any pics of the plate?
Reply #21September 29, 2008, 09:58:06 am
« Reply #21 on: September 29, 2008, 09:58:06 am »
If you really want ball bearing you can get a standard T3-T4 flanged manifold off E bay then get what ever you want.
Reply #22September 29, 2008, 10:48:17 am
stewardc
« Reply #22 on: September 29, 2008, 10:48:17 am »
Quote from: "zukgod1"
Are there flanged manifolds for an AAZ on eBay ????
A manifold must be matched to the head it's to be used on.
Reply #23September 29, 2008, 10:53:59 am
« Reply #23 on: September 29, 2008, 10:53:59 am »
WOW!!
REALLY!?!???
You cant just bolt any old manifold to the head??
Good hell man give me some credit.   :lol:
AAZ is the same as the 1.6 from what I remember.
There are manifolds available.
http://cgi.ebay.com/ebaymotors/VW-Golf-Jetta-2-0L-Turbo-Exhaust-Manifold-T3-T4-Flange_W0QQcmdZViewItemQQcategoryZ33742QQihZ020QQitemZ300261626019QQtcZphoto
Reply #24September 29, 2008, 11:55:45 am
blkboostedtruck
  • 1535
« Reply #24 on: September 29, 2008, 11:55:45 am »
Dale,
Dave(935racer) is selling a manifold simular to what Dan found link for!
in the forsale section!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #25September 29, 2008, 01:58:30 pm
monomer
  • 414
« Reply #25 on: September 29, 2008, 01:58:30 pm »
WOW!!
REALLY!?!???
I have the same manifold here (waiting to be used currently.)
The down side, it does not have a port for an external wastegate (I also have a tial 38mm waiting to be used...) I'm going to machine one in, since Cast iron is VERY tough to weld to and not have cracks develop.
Bigger wastegates control low boost better. I'm gonna be pushing 20psi through my merc t3/STI intercooler setup/
www.michiganvw.org
Reply #26September 29, 2008, 02:06:00 pm
« Reply #26 on: September 29, 2008, 02:06:00 pm »
Quote from: "monomer"
WOW!!
REALLY!?!???
You could make a small say 1" spacer to pull outof between the turbo and manifold?
Reply #27September 29, 2008, 02:20:28 pm
monomer
  • 414
« Reply #27 on: September 29, 2008, 02:20:28 pm »
I fear it may cause some lag.
the casting is thick enough to clean a flat area off and machine in the hole pattern and port.
I have to wait to see how everythings going to sit before machining, I dont feel like doing it twice...
www.michiganvw.org
Reply #28September 29, 2008, 07:19:20 pm
blkboostedtruck
  • 1535
« Reply #28 on: September 29, 2008, 07:19:20 pm »
i'm gonna argu that point cast iron is very easy to weld! knowing the process is the key!
pre-heat and stick weld with nickel rod ! the reason for nickel rod is it still can be machined! if it don't need any machining then 7018HR4 will do fine!
i'm a Ironworker by trade welding is my game
thanks Duane
'66 variant 1500S
Reply #29October 17, 2008, 01:13:48 pm
stewardc
« Reply #29 on: October 17, 2008, 01:13:48 pm »
This thread gives a greater description of my process and shows a couple of plates.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=16792
Andrew
Veeerrrrrry good. Thanks for this !
