Author Topic: My 1.6td/aaz head and other stuff too.  (Read 122569 times)
Reply #15September 23, 2008, 03:07:27 am
dillenger1
  • 777
My much anticipated 1.6td/aaz head.
« Reply #15 on: September 23, 2008, 03:07:27 am »
Nope ive got a shop that specializes in towmotor engines(idustrial engine).They are very similar to vw diesel.vw even makes an engine for Case towmotors.It was 300$ for eveything.magnaflux,bake/blast/bore/hone,straightness check.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #16September 24, 2008, 06:04:05 pm
  • 3468
    • McScrubbins Body Wash
« Reply #16 on: September 24, 2008, 06:04:05 pm »
I'm thinking of getting a windage tray and cam baffle from Myke to add to the list
Also, anyone do anything like this...
summer driving and winter driving you swap suspension, tires and bumpers?
I have big euros on it now and for winter i want ot put the stock springs back on with the big tires i have and stock bumpers so i have massive ground clearance again
and just swap for the seasons.
im going to get 4x4ing lights too to wire up so i can just plug them in and bolt them to a roof rack i have
Reply #17September 24, 2008, 06:40:02 pm
« Reply #17 on: September 24, 2008, 06:40:02 pm »
Go for it!
Personally I'm.shooting for coil overs so I can raise and lower as per season like you and I have a set of Saturn wheels with snow tires on them that I'll run as well. Leaving the bigs on though.
Reply #18October 04, 2008, 03:32:34 pm
  • 3468
« Reply #18 on: October 04, 2008, 03:32:34 pm »
OH the coillies are too low. I ahve them set as high as they can in the rear and it's still slammed. I could lower it at least 3 inches more if i had small enough rubber.
Reply #19October 04, 2008, 05:06:38 pm
ol'smokey95
  • 13
« Reply #19 on: October 04, 2008, 05:06:38 pm »
I'm looking at doing a bore on my AAZ  (1mm over on all 4) in the near future ; what brand name of pistons are the best ones to use? (Sorry if this is kinda high jacking the thread!? :lol: )
Reply #20October 04, 2008, 05:11:18 pm
  • 3468
« Reply #20 on: October 04, 2008, 05:11:18 pm »
I was going to do a 1mm over on all 4 but i don't have the funds. I was just going to get histon heads from Prothe and use the stock rods because the stock rods i've read are rediculously strong. Can take 200hp apperently.
edit: thats on my 1.6td
Reply #21October 15, 2008, 02:07:12 pm
  • 3468
« Reply #21 on: October 15, 2008, 02:07:12 pm »
After enormous deliberation i finally ordered my parts  :roll:
My final list is:
aaz head
7mm exhaust valves & guides
8mm intake valves & guides
re-using my lifters from the 1.6
the aaz cam
aaz HG
TDI ALH intake & gasket
the two garett T3 gaskets
ARP head studs
new standard size rings
EGT, oil temp, boost gauges. I need to find a temp gauge (i don't like the inaccuracy of the stock one)
Volvo intercooler
mercedez nozzles
Veggie seals in the pump
Gov mod and timing advance shim mod on the pump
I NEED TO STILL...make a spring compressor (Edit: CHECK!)
check that my water pump & oil pump are still OK (Edit: need water pump :( )
possibly rebuild my alternator if i start getting troubles (Edit: it looks ok!)
finish the tach converter chip to work for my gasser aftermarket tach (Edit: Proving extremely difficult...)
buy assembely lube and valve seating compound
and port & polish everyting.
Get the engine out &  Hone. (Edit: Engine still in there, no need for a hone)
wish me luck ...
Reply #22October 15, 2008, 02:34:34 pm
« Reply #22 on: October 15, 2008, 02:34:34 pm »
Looks like you have a good idea on what your trying to accomplish!
Good luck but I don't think your going to need it.  :D
Reply #23October 15, 2008, 02:36:18 pm
  • 3468
« Reply #23 on: October 15, 2008, 02:36:18 pm »
Well absolutely everything i know about diesels and VW's is from this site. I know some wrenching from courses i took but they don't really compare.
I still need the luck :P
but thanks i appreciate it. Holler at me if you see me over looking something or forgetting something because i will
I hope my intermediate shaft is okay too :(
common fix is a bearing change right?
Reply #24October 15, 2008, 02:44:13 pm
« Reply #24 on: October 15, 2008, 02:44:13 pm »
Quote from: "Smokey Eddy"
Usually the shaft is fine, the bearings are the issue.
Reply #25October 15, 2008, 03:52:53 pm
  • 3468
« Reply #25 on: October 15, 2008, 03:52:53 pm »
my block has 400,000kms on it and i dont know how much of that is on the rebuild i think it's had and who knows what's been changed on it. So ... I guess i'll just have to see. What should i be looking for? play in any axis for the main bearing? general Looseness? should there be "some"?
I uninsured it today  :cry:
hopefully yesterday wasn't it's last day on the road.
uhhh so i've been driving with the cam 180 degrees out
woops...or the flywheel 180 degrees out
Reply #26October 24, 2008, 03:42:42 pm
  • 3468
« Reply #26 on: October 24, 2008, 03:42:42 pm »
I need help choosing paint.
Can anyone post pictures of paint they think looks good on an mk2 jetta?
Brands? suppliers?
I have an HVLP i can use and like 5 canisters so i can have several colours depending on how much the paint costs.
Please let me know!
I want to do two colours. Maybe an under tone or something.
Of if anyone knwos of a straight colour that looks good?
I can't do anything too fancy like metalic flakes because the body isn't in good enough shape to merit that kind of investment.
Reply #27October 24, 2008, 04:56:43 pm
TurboJ
  • 661
« Reply #27 on: October 24, 2008, 04:56:43 pm »
Tornado Rot all the way!
Jetta II 1.6 TD 'Project 200'
Reply #28October 24, 2008, 04:58:50 pm
  • 3468
« Reply #28 on: October 24, 2008, 04:58:50 pm »
I was thinking something less ... factory. Because i have the option to do so.
ok im thinking a glossy black!!! (but its still a stereo typical factory colour)
or should i do a professional flat black job to cover up my very poor roller job?
Flat black just stays rough and gets dirty very easily I'm not sure what to do
but it covers imperfections the best....
gah! i need help choosing! :P
Reply #29October 27, 2008, 07:17:23 pm
  • 3468
« Reply #29 on: October 27, 2008, 07:17:23 pm »
Thanks for the tremendous input for paint, guys :roll: .
I have some stuff that maybe useful to someone at some point.
My lifters are smooth as glass!!! but they look strange. like these rings
The spring compressor i had...
Didn't work because the arms are different lengths  :evil:  :evil: (Yes, i cut my self the day before taking the head off)
I was tired of struggling with the keepers so i altered my LDA. Those screws did NOT want to come off.
So, i used the same method i used to get my brake calipers apart.
Smash it onto the head of the screw carefully as to avoid damaging the precious IP and out it comes!
I have no CLUE why bosch used flat head screws for this? i much prefer torx  :D  :P (or what ever socket that is)
I asked a question about getting the shizz out of the thread holes for the studs/bolts and someone said to use compressed air ...  :roll: I let brake cleaner/lacquer thinner sit in there for an hour or so and then used "compressed air" to get it all out! (being very careful to block all coolant and oil holes.
This is my sad attempt at a spring compressor. Who doesn't like wood?  :wink:
This is a tiny neodymium magnet from a screw driver. My intent was to grab the keepers out with it and press the valves down with a socket
This didn't work, which wasn't surprising, but i was hoping someone could give me a tip or something? I'm trying to avoid grinding a socket, mostly because i don't have a grinder and filing would take forever (hack sawing would be very hard as well because im not sure how I'd clamp it. I don't have a vise.. only clamps... My garage is a wood shop and I've commandeered it to fix my veedub so please, bare with me :roll:
