Author Topic: what clutch?  (Read 23341 times)
Reply #15June 29, 2004, 05:06:14 pm
fspGTD
  • 1529
what clutch?
« Reply #15 on: June 29, 2004, 05:06:14 pm »
Here are a few links from the old forum on clutches:
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=40
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=319
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=609
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=679
I think that should about cover it, as the topic has come up quite a few times in the past... (unless you have some other questions that haven't been covered, in which case, shoot!)
Jake Russell
Reply #16June 29, 2004, 07:22:10 pm
VWRacer
  • 649
what clutch?
« Reply #16 on: June 29, 2004, 07:22:10 pm »
Woo hoo! It seems that I have the best of all worlds... :shock:  :D
Here is a photo of the flywheel from one of my spare VW GTI engines. The numbers read 29072 and 022 105 273. Note that it is 190mm from outer ring to outer ring. If I need to use a stock flywheel, at least I have the smallest one available.
Jake, did you have a thread where you described how you had it lightened?
Thanks, Stan
Stan
C-Sports Racer
Reply #17June 29, 2004, 09:16:27 pm
VWRacer
  • 649
what clutch?
« Reply #17 on: June 29, 2004, 09:16:27 pm »
No...I'm happy because I have a small flywheel. A bigger clutch means a bigger flywheel, which means more rotational inertia, which means slower acceleration. These things are all bad from a racing perspective.
May not mean much to a guy looking for maximum fuel mileage... :D
Stan
C-Sports Racer
Reply #18June 29, 2004, 09:38:21 pm
BlackTieTD
  • 1512
what clutch?
« Reply #18 on: June 29, 2004, 09:38:21 pm »
Quote from: "VWRacer"
although, wouldn't less rotational inertia translate to slightly better fuel mileage? might be negligable, but in theory?
Reply #19June 30, 2004, 08:26:50 pm
  • 2926
clutch weight
« Reply #19 on: June 30, 2004, 08:26:50 pm »
Ok, if I'm wrong someone correct me.
  The flywheels for the 190mm and 210mm clutch have the same outside diameter right?
Reply #20June 30, 2004, 11:29:20 pm
fspGTD
  • 1529
what clutch?
« Reply #20 on: June 30, 2004, 11:29:20 pm »
Stan is right... for all-out racing, they use the smallest clutch and flywheel that you can get away with.
Here is the thread where I describe my setup:
I actually have a 200mm setup.  But based on my research I actually heard some conflicting opinions on which setup would ultimately be lighter (190mm or 200mm) but for sure either are pounds lighter than a 210mm setup.
The OD of the flywheel is the starter engagement teeth, which is the same for all the clutch diameters.  What changes is the OD of the clutch disc (smaller OD = slightly lighter clutch) and the OD of the pressure plate (smaller OD = significantly lighter pressure plate, by like 2 pounds or more going from 210mm to 200 or 190mm.)  I have heard that the 190mm, 200mm, and 210mm flywheels should weigh about the same after they've all been lightened to about the max limits, but then again it depends on the skill of the machinist doing the lightening.  Where the weighs gets saved by reducing clutch diameter is mainly in the pressure plate.
Here are some pictures of my setup taken from the thread mentioned above:
Jake Russell
Reply #21July 01, 2004, 06:59:54 am
Dr. Diesel
  • 1341
what clutch?
« Reply #21 on: July 01, 2004, 06:59:54 am »
eurodrive clutches in burlington. they will lighten flywheels too, or make you an aluminum unit. I think the clutch disc was roughly double the price of a regular material unit, but they grip way better and last 3x longer.
Reply #22July 01, 2004, 12:05:59 pm
fspGTD
  • 1529
what clutch?
« Reply #22 on: July 01, 2004, 12:05:59 pm »
I have looked into, but never found an aluminum flywheel being actually made or sold for an 020 transmission.  And the people I found who advertised it, never actually made one and when they looked into it further, they decided they couldn't/wouldn't do it.  My impression is that it would take a really thick slab of aluminum, a lot of $, and wouldn't save much weight vs a properly lightened OEM cast iron unit, but I'd be very interested in hearing if someone's actually made one and how much it cost and weighs.
Jake Russell
Reply #23July 01, 2004, 09:39:26 pm
Cheesetoast
  • 285
what clutch?
« Reply #23 on: July 01, 2004, 09:39:26 pm »
so if i upgrade to a 16v clutch/pressure plate and a 8pound 16v flywheel instead of my 93 td stock setup, will i get less fuel milage? :?:
Reply #24July 01, 2004, 10:33:09 pm
moosiah
  • 106
what clutch?
« Reply #24 on: July 01, 2004, 10:33:09 pm »
just for grins an' giggles I took a scale out to the rabbit hutch and weighed all 3 of my clutchs, a 190, 200 (off my 1.6td) and :: a 210. all were complete as removed from their engines.......... they all weighed 23 pounds total .... so just where do I send a flywheel to get it lightened ???? and can they do it with out milling off the timing marks?? :?:
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #25July 02, 2004, 04:49:26 pm
Dr. Diesel
  • 1341
what clutch?
« Reply #25 on: July 02, 2004, 04:49:26 pm »
Eurodrive had an experimental clutch a friend of mine was using. They put the friction material on the pressure plate and flywheel, and had a naked clutch disc. The idea was with a drastically lighter disc, shifting would occur much faster. This also used one of their 020 aluminum flywheels, which was 5 lbs (as I remember). I have an aluminum VR6 flywheel done by them, too. (haven't tried it yet)
Reply #26September 18, 2004, 01:33:19 am
Cheesetoast
  • 285
what clutch?
« Reply #26 on: September 18, 2004, 01:33:19 am »
talked to a vw place that did my friends gti vr6 flywheel/clutch, and he said with diesels, lightening hte flywheel wil ltake away torque, he suggested putting a HEAVIER one in if anything, any thoughts? or is this a " :roll: "
Reply #27September 18, 2004, 06:23:13 am
QuickTD
  • 1156
what clutch?
« Reply #27 on: September 18, 2004, 06:23:13 am »
I lightened the flywheel by about 2 pounds when I did my clutch. All I can say is that I wish I had lightened it more. I love the quick revving. It also seems alot smoother, but I had the flywheel balanced after machining so it may just be better than stock. I'd recommend a lightened flywheel to anybody, there are no drawbacks that I can see.
Reply #28September 18, 2004, 06:32:36 am
VWRacer
  • 649
what clutch?
« Reply #28 on: September 18, 2004, 06:32:36 am »
I recently purchased this clutch kit from Virtual World Parts.
It may be more than you're looking for, but it needs to last me 25 hours of all-out road racing. And even though it's designed for an 8V GTi, Mike Potter at Virtual assured me that it'll go into any early Rabbit. The rules in my class prohibit lightened flywheels (they must be stock), but the clutch and pressure plate are open.
Stan
C-Sports Racer
Reply #29September 18, 2004, 06:41:12 am
VWRacer
  • 649
what clutch?
« Reply #29 on: September 18, 2004, 06:41:12 am »
Quote from: "Cheesetoast"
To put it politely, the guy doesn't know what he's talking about. A heavy flywheel has no place on a modern high-revving diesel, other than as an aid for drivers with poor manual tranny skills. Lighten that sucker as much as you can...you'll love it! :D
Stan
C-Sports Racer
