Author Topic: gasser manifolds  (Read 6924 times)
Reply #15September 18, 2008, 07:25:40 am
  • 1739
gasser manifolds
« Reply #15 on: September 18, 2008, 07:25:40 am »
Yes but are there any that match up to a 1.9 na with the "d' shaped inlets?
Reply #16September 18, 2008, 09:34:52 am
dieselwagen
  • 85
gasser manifolds
« Reply #16 on: September 18, 2008, 09:34:52 am »
Quote from: "danwithagolf"
so dieselwagen the intake mani you have what motor is that off of and what year car? i went to a auto wrecker the other day to take a look and i see tons of 8v 86-92 golfs and jettas your intake looks a bit diff tho. thanks dan
dan, when i pulled that intake off a car i have no way of identifying the wreck, bonnet and hood support is gone and driver door is caved-in. all of the rear badges are gone.
the only part # it has on the casting is {037133223A} maybe a local dealership can help decipher those numbers and help identify the intake.
1986 golf 1.6
Reply #17September 18, 2008, 10:39:33 am
  • 1739
gasser manifolds
« Reply #17 on: September 18, 2008, 10:39:33 am »
This is all well and good, but are there any that match up to a 1.9 head with the "d" shaped inlets ?
Reply #18September 18, 2008, 10:41:48 am
gigaz2
  • 626
gasser manifolds
« Reply #18 on: September 18, 2008, 10:41:48 am »
in that case you want a 1Y intake, its better than the gassers, only "downside" is it only fits the 1.9 diesel head.
Reply #19September 18, 2008, 02:36:36 pm
dieselwagen
  • 85
gasser manifolds
« Reply #19 on: September 18, 2008, 02:36:36 pm »
Quote from: "the caveman"
PM sent
1986 golf 1.6
Reply #20September 18, 2008, 02:48:18 pm
gasser manifolds
« Reply #20 on: September 18, 2008, 02:48:18 pm »
his is either a g60 intake or a fox intake or a mk1 intake,  mk2 intakes are have the throttle on the passenger side...  using the gas intake with a long tube going to the front of the car would be a good way to get rid of some of the diesel clatter with out losing any power. although power wise i think the na intake is pretty adequate except for the the snorkel, part.
Reply #21September 18, 2008, 05:16:04 pm
  • 1739
gasser manifolds
« Reply #21 on: September 18, 2008, 05:16:04 pm »
I think i will be just going to use a 1.6 na intake which i have now welded up to match to the d ports. I would think that it has somewhat of a plenum effect and i will then just enlarge the intake pipe size which will then be piped to a cold air intake snorkle
Reply #22September 19, 2008, 12:30:09 am
danwithagolf
  • 43
gasser manifolds
« Reply #22 on: September 19, 2008, 12:30:09 am »
hmm ok well i have the stock n/a intake i got a k&n filter in it i think all stick with that i am going to pick up a exhaust mani tho i think that will free up a bit of restriction thanks for all the replies guys    dan
87 Golf n/a
