Black Nitrous button? what the heck is it?
Topic: Black Nitrous button? what the heck is it? (Read 2794 times)
August 18, 2008, 02:13:54 am
August 18, 2008, 02:13:54 am »
On my IP there was a black button that would get pressed at full throttle but there were no leads on the conector??? it has a VW symbol on it but what the heck is it?
I took it off ages ago and just read someone mentioning it. i can't find any unused leads to go to it either. For a mechanical engine i would have never though to find a switch like this. Anyone know?
if you need a picture just say
Thanks,
Ed.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
August 18, 2008, 03:04:58 am
dillenger1
August 18, 2008, 03:04:58 am »
cruise control?
1.6td in toyota pickup
10mm head ,t3 intercooled.
August 18, 2008, 06:55:39 am
August 18, 2008, 06:55:39 am »
Its supose to shut off the AC at full throttle.
August 18, 2008, 07:37:55 am
blkboostedtruck
August 18, 2008, 07:37:55 am »
I thought it was the beam me up scotty balck button? :roll:
L.O.L.
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
August 18, 2008, 08:37:32 am
August 18, 2008, 08:37:32 am »
Well maybe on your car Duane :?
August 18, 2008, 09:28:15 am
blkboostedtruck
August 18, 2008, 09:28:15 am »
hey i took it off! i thought it would have been a one way trip man? :wink:
L.O.L.
Duane
'66 variant 1500S
August 18, 2008, 01:35:58 pm
August 18, 2008, 01:35:58 pm »
Huh well then...
thanks. It was really ... stumping me. Especially since it was on my car...
A car with no visible existance of AC
THROWN ROD
August 19, 2008, 05:35:55 am
Dr. Diesel
Authorized Vendor
August 19, 2008, 05:35:55 am »
it might have to do with the upshift indicator system.
August 19, 2008, 01:44:48 pm
arb
August 19, 2008, 01:44:48 pm »
I had a 1978 Rabbit diesel with A/C and there was switch that cut out the compressor clutch at full throttle...
August 19, 2008, 06:27:10 pm
August 19, 2008, 06:27:10 pm »
i don't have an upshift system either...
maybe my car found a new pump somewhere and it was on it?
THROWN ROD
August 19, 2008, 07:23:39 pm
Jet A
August 19, 2008, 07:23:39 pm »
sounds like you anwsered your question with your title.
Its a black nitrous button....maybe not yet....but it will be
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #11
August 19, 2008, 07:28:35 pm
Reply #11 on:
August 19, 2008, 07:28:35 pm »
Ah AHAHAHHAHA! YESSS! Or, in our case LPG!!!!
LPG LPG LPG LPG LPG!!!
THROWN ROD
