Author Topic: Cam nuts torque specs?  (Read 12673 times)
August 13, 2008, 08:44:14 pm
  • 3468
    • McScrubbins Body Wash
« on: August 13, 2008, 08:44:14 pm »
Can anyone shout me the torque specs for the cam nuts on a 1.6 hydraulic head.
I can spin the lifters freely and i put a wrench on one and it turned relatively easily and left me with a  :( / :shock:  face...
also, there are very slight circles on the pistons as if the valves hit them at some point but very very faintly. They seat alright for being as old as they are but i've never taken them apart from the head to really take a look. The car still runs so i don't think they got damaged toooo too badly. I'm waiting for a new head anyways but i was just curious
cheers,
Ed.
Reply #1August 14, 2008, 01:06:30 am
  • 3468
« Reply #1 on: August 14, 2008, 01:06:30 am »
Anyone?
15 Nm?
i hope more than that...
30 Nm?
Reply #2August 14, 2008, 05:56:57 am
« Reply #2 on: August 14, 2008, 05:56:57 am »
15 Ft/lbs if they are the same as a 1.9, which they probably are.
Reply #3August 14, 2008, 01:43:00 pm
arb
34 ft/lbs
« Reply #3 on: August 14, 2008, 01:43:00 pm »
My 1.6L Bradly books quotes 34 ft/lbs. That is what I used yesterday. It felt right.
Reply #4August 14, 2008, 05:35:33 pm
  • 3468
« Reply #4 on: August 14, 2008, 05:35:33 pm »
im going to go with 15.....
thanks guys!
(hope you didnt fuxxor yours with 34! :O )
Reply #5August 14, 2008, 05:35:50 pm
  • 3468
« Reply #5 on: August 14, 2008, 05:35:50 pm »
maybe 34 Nm?
Reply #6August 14, 2008, 06:33:44 pm
Quantum TD
  • 1195
« Reply #6 on: August 14, 2008, 06:33:44 pm »
It's 20 nM.
Reply #7August 15, 2008, 11:35:56 am
arb
cam nut
« Reply #7 on: August 15, 2008, 11:35:56 am »
Yeah, I thought you were talking about the cam nut torq for the PULLEY :-) That's the 34 ft/lb - not the tiny bearing caps. Yeah, you'd likely snap them off if you did 34 ft/lb for the cam bearing nuts...
Reply #8August 15, 2008, 01:51:54 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #8 on: August 15, 2008, 01:51:54 pm »
I have been bitten by this before. A helicoil kit and battery drill using the cam cap as a guide and Lots of carefull rag stuffing to catch the swarf then an oil change worked fine, thats 45,000 miles ago. 8)
Reply #9August 18, 2008, 02:17:58 am
  • 3468
« Reply #9 on: August 18, 2008, 02:17:58 am »
Jesus my cam and crank nuts i tighten until i think to my self (ok no more or else bad things will happen) which is way more than 34 ft/lbs according to my torque wrench. 34 really isn't that much. And i can't BELIEVE the cam nuts are alright so loose but i guess its all machined so perfectly and perfectly balanced it doesnt need to be pointlessly tight. thanks guys prob. solved. She runs alright now with new metal 1.9HG and oil. Still has issues starting hot though... oh well rebuild soon
Reply #10August 18, 2008, 07:04:44 am
captainpartytime
  • 39
« Reply #10 on: August 18, 2008, 07:04:44 am »
Quote from: "libbybapa"
FWIW, I know of several times that the cam pulley has slipped with the 33 ft. lb. spec. I torque mine to 45.
Well, now you've got me thinking Andrew. What about the 33 ft. lbs. for the IM shaft? Should that also be torqued to 45? It may also be helpful to point out that the 12 sided bolt w/o washer for the crankshaft sprocket to crankshaft is a stretch bolt and should not be re-used. Correct?
-Kerry
1982 Diesel Westfalia Vanagon
1989 Wolfsburg 7-Passenger Vanagon
