Author Topic: Fuel gauge not working. the tank is always "empty"  (Read 3392 times)
April 23, 2008, 01:56:53 pm
varg300
« on: April 23, 2008, 01:56:53 pm »
The gauge has never worked as long i have had the car.
Even if i fill the tank completly full, the gauge still says that the tank is empty. I have just reset the trip-meter every time i have filled, but this is starting to get annoying. Where is it most likly that the problem is? The sensor, or the gauge itself?
And one more thing, i have just attached a tacho, but what is the idle rpm for the engine?
Reply #1April 23, 2008, 02:34:08 pm
« Reply #1 on: April 23, 2008, 02:34:08 pm »
Idle should be around 700-1000. I set it to wherever it shakes the least.
I'd start by looking under the rear seat with a ohm meter on the fuel gauge sender. You could actually take it out and move it and you should get varying resistance. If that is good I would suspect the wires and then the cluster.
