Author Topic: Compressor diesel? more power from diesel  (Read 13881 times)
March 14, 2008, 02:29:10 pm
Benjamin
  • 485
« on: March 14, 2008, 02:29:10 pm »
guys, i have a small idea,
i think the main problem with making big power is not feuling, but getting that big turbo spooled up... (exept if you pay big money for ballbearing hybrid turbos) diesels cant make so great power gains like gasoline engines do, and feul is a restriction, becouse off the pump, but we havent seen a 12mm feuled out with IDI, and we still have the 14mm, but it also have limits becouse you do need to inject it fast enough and it need to burn fast enough also, but i dont think we have seen the limits!
i think there are several thoughts about building a G40-G60 on a diesel with many pro and contra's...
i have the idea to build a compressor, as you know there are several compressor.
roots
dont know the name in english...
G-compressor or Scroll compressor
Comprex wich is a nice system, but simply not good cause you dont have high power outputs in no any way, and its also pretty complex
and than, you have the centrifugal compressor, for those who dont know, the centrigugal compressor is the intake from a turbo, and the shaft is (mainly) connected to the engine.
those compressors make about 40.000rpm
the good and bad thing about this one is, its very small and very efficient, but this type is rather for cars with peak power and just a little torque, this is thee reason why you dont find them on normal cars.
Now i was thinking about taking a pretty big turbo, take the turbine off, and build a centrifugal compressor myself. but this time not pushed by the engine, but with an electrical engine or so!
Anyone have an idea or so, what kind of power need the electric engine be, how to make fast rpm trough reductions, what about the bearings, or is it better to push the compressor with another engine than electric, i dont know if its possible, but can a turbine from the turbo be turned on when you add feul to it, some kind of JET system, only you dont use the compressor, just a thought.
Greetz, Benjamin
Must make +250hp
Reply #1March 14, 2008, 02:32:18 pm
« Reply #1 on: March 14, 2008, 02:32:18 pm »
theres actually a guy that did exactly that, he sells a kit too
Reply #2March 14, 2008, 02:47:36 pm
Benjamin
  • 485
« Reply #2 on: March 14, 2008, 02:47:36 pm »
Quote from: "Trev0rbr"
With a centrifugal, what kind of power gains did he make? He did it on diesel?
Greetz, Benjamin
Must make +250hp
Reply #3March 14, 2008, 02:54:46 pm
« Reply #3 on: March 14, 2008, 02:54:46 pm »
he did it on a beetle, there was a post in this forum a little while ago for it.  pretty neat but it was only good for short bursts of power, and the powergain was relatively weak imo.
Reply #4March 14, 2008, 03:11:11 pm
Benjamin
  • 485
« Reply #4 on: March 14, 2008, 03:11:11 pm »
link to forum
http://vwdiesel.net/phpBB/viewtopic.php?t=10210&highlight=electric+turbo
link to example
http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/index.html
i dont know if this is centrifugal compressor, its my understang its not, probably becouse this one makes 4x less rpm
Greetz, Benjamin
/edit:
T: When did you develop the idea of using three motors?
TK: About 10 years ago I developed a program to determine the horsepower requirements for electric compressors. It was a very difficult program and it took me a long time to get the parameters correct. I found that flowing 780cfm at 15 psi required 80 to 100 hp. I went smaller on engine size and lowered boost requirements until I reached 450cfm at 8 psi, which required 18 to 22 hp, so I looked for a 20-hp dc motor. All I found were 50-plus-pound motors, which were too large to use in my intended application. Three years ago I realized if I used multiple motors, I could get to the 20-hp mark.
T: Why a Roots-type supercharger?
TK: I designed many different models and applied for the patents. I also have patents pending on screw, roots, centrifugal and sliding vane-type electric superchargers. The centrifugal design is in the works, and the screw is simply too expensive to use. The sliding vane is great but quite large, so the Roots is cost effective, reliable, simple, durable, and provides the quickest boost response.
Must make +250hp
Reply #5March 14, 2008, 03:29:44 pm
blkboostedtruck
  • 1535
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6March 14, 2008, 03:45:29 pm
Benjamin
  • 485
« Reply #6 on: March 14, 2008, 03:45:29 pm »
so, any other idea's to make the turbine flow, without taking power from the engine like exhaust gasses, mechanical on a belt, or electrical wich is also mechical becouse of your alternator.
Need a 5th injector and a sparkplug to make that turbine spooling, or what?
Greetz, Benjamin
Must make +250hp
Reply #7March 14, 2008, 05:50:56 pm
KTZed
  • 170
« Reply #7 on: March 14, 2008, 05:50:56 pm »
Have a second alternator and battery dedicated to the electric supercharger. Have the alt run off of a magnetic clutch pully from an AC compressor so that when full throttle is applied the clutch is disengaged so as to not drain power from the engine when you need it most.
You could wire it so that during normal driving the alt would be engaged, charging the battery and have the gas peddle wired as a potentiometer to controll the speed of the supercharger.
Yes I have put some thought into this in the past  :roll:
PS. Speaking of twincharged engines...
HKS once made a turbo kit for the superchaged Toyota MR2 and VW now makes a TSI 1.4L twincharged gas engine.
Many old Detroit 2 cycle diesels are supercharged and twin turbo.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #8March 14, 2008, 06:16:48 pm
shegel
  • 312
« Reply #8 on: March 14, 2008, 06:16:48 pm »
here is a link to a topic i started involving a twin charged mercedes diesel.
http://vwdiesel.net/phpBB/viewtopic.php?t=11908&highlight=mercedes
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #9March 14, 2008, 07:50:05 pm
blkboostedtruck
  • 1535
« Reply #9 on: March 14, 2008, 07:50:05 pm »
i finally found the answer to my question click here
vw did a twin induction kewl!
Duane
'66 variant 1500S
Reply #10March 14, 2008, 08:45:12 pm
Black Smokin' Diesel
  • 656
« Reply #10 on: March 14, 2008, 08:45:12 pm »
That's why they developped VNT turbos.
Reply #11March 14, 2008, 11:25:40 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
Re: Compressor diesel? more power from diesel
« Reply #11 on: March 14, 2008, 11:25:40 pm »
Quote from: "Benjamin"
Twin Screw compressor, the new air compressor at work is that type
Always wondered about bolting an Atlas Coppo screw compressor to an engine from a pneumatic drill/jack hammer compressor
in fact why fit a turbo or supercharger when you can just tow one of these behind you :roll:
its a bolt on towable twin screw supercharger :wink:
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #12March 15, 2008, 04:31:25 am
burnt_servo
  • 278
« Reply #12 on: March 15, 2008, 04:31:25 am »
wouldn't it be easier to use a set of compund turbo's  ?
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #13March 15, 2008, 05:15:24 am
haybayian
  • 155
« Reply #13 on: March 15, 2008, 05:15:24 am »
Quote from: Benjamin
Interesting subject B
My own crazy idea is that the design of combustion engines including diesel IC needs to be revisited from the ground up. When we look at performance we do not differentiate between "continuous duty" and "discontinuous on demand type of duty" the way most machinery is normally rated in the industrial sector.
On cars I see a need for cruising and a need for passing (or impressing). The latter is rarely ful time and the engine does not need to be designed for it.
In other words we should make engines capable of storing energy and this I think can be done either in the form of DC electricity fed supercharger, or by storing high pressure air to be injected in a diesel intake without turbo or supercharger.
This is what I am looking at. An air compressor with a magnetic clutch ran by the alternator belt, a high pressure air tank, a throttle link type of control,  some sort of a cooler and a hose to the intake manif.
Here is my supercharger...please don't  laugh.
Haybayian
Keep it simple if you can.
Reply #14March 15, 2008, 06:41:23 am
just a thought
« Reply #14 on: March 15, 2008, 06:41:23 am »
My thinking is that any engine uses about 1/3 of the energy it makes to power the car, 1/3 is wasted in aerodynamics and the other 1/3 is lost in exhaust heat. Why not use the 1/3 of the exhaust heat to power a fan *turbo* and use a little of that wasted heat...your making it anyway.
