Author Topic: 6.5 l td turbo  (Read 3013 times)
April 16, 2005, 10:15:51 am
SMOKEYDUB
  • 630
6.5 l td turbo
« on: April 16, 2005, 10:15:51 am »
Ok I have another project on the go besides the smokey jetta. I am also working on a 1980 Z28 and I recently picked up a turbo out of a 6.5l td and I am going to put it on the camaro. Everyone gasser guy that knows anything about turbos say that diesel turbos are poor. I just want to know if this turbo will hold up and not fly apart. It's going on a 5.7l small block chev.
Sorry about the non diesel topic.
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1April 16, 2005, 01:11:49 pm
Dr. Diesel
  • 1341
6.5 l td turbo
« Reply #1 on: April 16, 2005, 01:11:49 pm »
i would think that it's big enough to at least not come apart. there were some early 80's firebirds that came with a turbo v8. give it a shot and see what happens. Actually, for some time I had wanted to try making a twin-turbo, twin CIS v8. each cylinder bank had it's own turbo and cis fuel injection. probably a pair of K26's would work great.
Reply #2April 17, 2005, 08:00:36 am
VWRacer
  • 649
6.5 l td turbo
« Reply #2 on: April 17, 2005, 08:00:36 am »
Hey Jeff, there is a really complete website dedicated to the early turbo'd Buicks and Pontiacs. Mainly V-6 stuff, but a few pages to the turbo'd V-8's, plus tons of links and tech tips. Check it out...  8)
Turbo Buick Website.
Stan
C-Sports Racer
Reply #3April 17, 2005, 10:29:58 am
fspGTD
  • 1529
6.5 l td turbo
« Reply #3 on: April 17, 2005, 10:29:58 am »
I've read that some turbos that came on diesel applications do not have compressor bearings / seals capable of handling vacuum and/or fuel in the compressor.  On a diesel there is never vacuum or fuel in the compressor because no throttle valve exists, and fuel injection is direct into the head.  On a gasser application you might run into a problem with a diesel turbo if you have a "draw through" carburator setup and/or if yo have the throttle valve mounted before the turbo (rather than in between turbo and intake manifold).
Two good books you should look at are "Turbochargers" by Hugh MacKinnes and "Maximum Boost" by Corkey Bell, both oriented towards homebrew turbo swaps, and explain these types of things plus more.
Jake Russell
Reply #4April 17, 2005, 02:23:47 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
6.5 l td turbo
« Reply #4 on: April 17, 2005, 02:23:47 pm »
just had a thought and sorry this is further afield....
remember the LPG injection stuff guys? what about using gasser turbos to make injecting that gas into ur turbo smoker safer?
just a thought
aydan
'91 Golf Cabrio 1.9TD
Reply #5April 18, 2005, 03:09:09 am
Patrick
  • 1034
6.5 l td turbo
« Reply #5 on: April 18, 2005, 03:09:09 am »
The trans am that came turbo'ed had the little 301 engine, a whole different animal than a 350. I think I'd want to do a lot of research before I tried this. Aren't the ratio's a lot different on diesel vs gas turbo's? How about 2 turbos off the early ford 4 cylinder gassers instead? One on each side. I Knew a guy that put one of the early mustang motors in a ranger pickup, wastegate was stuck and the this regularly put up 15 pounds of boost, about twice what it was supposed to.
