Author Topic: dissassembly of injection pump  (Read 4175 times)
April 09, 2005, 08:21:41 pm
Justin
  • 455
« on: April 09, 2005, 08:21:41 pm »
so i have 2 pumps not working and I decided to tear one apart and see if i could get it working again, well i think that i can but i need a special tool i think to take out the govenor thing (i think thats what it would be called)
it looks like it requires a tool that resembles a circle with 3 flat spots cut out on it, not real sure what it is called and where to get it so any help would be appriciated
thanks in advance
Justin
www.archeryprostaffmi.com
Reply #1April 10, 2005, 11:52:13 am
chrissev
  • 694
Re: dissassembly of injection pump
« Reply #1 on: April 10, 2005, 11:52:13 am »
Quote from: "Justin"
thanks in advance
Justin
try contacting Bosch.  They make those pumps.  You'd probably have to order it through a distributer though as my experience with Bosch is they don't sell to the public
Reply #2April 10, 2005, 10:31:06 pm
  • 2926
tool
« Reply #2 on: April 10, 2005, 10:31:06 pm »
I think I took a 6 point 13mm and ground off every other section.
Reply #3April 10, 2005, 10:40:35 pm
jackbombay
  • 599
« Reply #3 on: April 10, 2005, 10:40:35 pm »
"Metalnerd" sells one for the TDI pumps, I think it is the same size on the IDI pumps, but the socket is $20 or so IIRC. I think you can also get a 7/16" 12 point on thee with a hammer IIRC.
Reply #4April 11, 2005, 01:06:30 pm
watsongs
  • 135
« Reply #4 on: April 11, 2005, 01:06:30 pm »
Justin, I'm about to do the same, but I think I'll wait and see what you find out -
Greg Watson
'79 Rabbit, 1.5 liters of fun...
If they can get you to ask the wrong questions, they don't have to worry about the answers...
Reply #5April 11, 2005, 01:15:03 pm
Justin
  • 455
« Reply #5 on: April 11, 2005, 01:15:03 pm »
i think what i am going to do is what fatmobile suggested and to take a die grinder to a junk 13 mm 6 point socket and round out 3 flat spots, I will let you know how it turns out saturday since i am away from my tools for the week
later
justin
Reply #6April 16, 2005, 08:10:52 pm
Justin
  • 455
« Reply #6 on: April 16, 2005, 08:10:52 pm »
well i rounded out three flat spots on a 13mm 6 point socket and it seemed to large, so I did the same to a 12mm and it worked perfect, and now that old junk pump after tearing it apart and chem dipping everything then reassembling it works great, now i just need to get some viton seals and swap it out and brew some bio diesel
thanks guys
Justin
Reply #7April 16, 2005, 09:44:55 pm
watsongs
  • 135
« Reply #7 on: April 16, 2005, 09:44:55 pm »
It works great?  And everybody says they're not fixable...  Since my old pump was destined for a bookned, I'm even more looking forward to tearing it apart.  Though I have a nasty hbait of finding extra parts after I've re-assembled it...  Let me know ehn you find those seals and what they cost.  I'm a few steps away from a-brewing myself...
Greg Watson
Reply #8April 17, 2005, 07:11:29 am
Justin
  • 455
« Reply #8 on: April 17, 2005, 07:11:29 am »
seems to work good on the bench, i have yet to put it on a engine and test it
here is what i have found on the seals provided this is the correct type of seal
HARWAL
Justin,
The following item:
17 x 28 x 07ADL VITON  $12.41 ea.  Minimum 4 pcs
Let me know!
Regards,
Rob Andreoletti
HARWAL
i think that wehen i do order new seals that i am going to take measurments of all the orings and such to get all viton seals and i will post the specs and prices of all the seals when i get around to it
Reply #9April 17, 2005, 07:13:04 am
chrissev
  • 694
« Reply #9 on: April 17, 2005, 07:13:04 am »
thanks guys
Justin
how did you adjust it?  everyone says you need a test bench to do that.  Did you just guess at the settings?
Reply #10April 17, 2005, 01:57:13 pm
Justin
  • 455
« Reply #10 on: April 17, 2005, 01:57:13 pm »
well its not adjusted yet, i was able to keep the current settings except for the idle since i kept all of the settings marked and recorded, so in order to set it proberly yes i would need the test bench or an engine to run it on
which hopefully i will soon have an engine on a test stand to test pumps
later
justin
