Author Topic: Electric Fuel Pump  (Read 2704 times)
March 02, 2008, 08:20:02 am
TPW
  • 113
Electric Fuel Pump
« on: March 02, 2008, 08:20:02 am »
I picked up another Audi 5000 Turbo Diesel for my next project, and it had something on the engine I wasn't familiar with.  Between the injector pump and the fuel filter was an electric fuel pump.  The owner said he had only started the car once, but the fuel pump had to be running.  Were these standard on 1983 cars, or does this indicate problems with the injector pump?
Reply #1March 02, 2008, 08:23:12 am
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
Electric pump not needed
« Reply #1 on: March 02, 2008, 08:23:12 am »
Hey
you're right the electric pump does indicate a problem with the internal
pump of the VE injection pump. if it won't suck fuel from the tank
then the blades inside the VE are most likley stuck. it's not a good
idea to run it like this.
Giles
Reply #2March 02, 2008, 08:24:52 am
blkboostedtruck
  • 1535
Electric Fuel Pump
« Reply #2 on: March 02, 2008, 08:24:52 am »
sounds like a problem with the pump or fuel lines
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3March 02, 2008, 02:09:28 pm
zaprzal
  • 160
    • turbodiesel.pl
Re: Electric pump not needed
« Reply #3 on: March 02, 2008, 02:09:28 pm »
Quote from: "Giles@PerformanceDiesel"
Hey
Giles
using additional lift pump in tank is bad?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #4March 02, 2008, 03:42:29 pm
Benjamin
  • 485
« Reply #4 on: March 02, 2008, 03:42:29 pm »
Quote from: "zaprzal"
Hey
Giles
no, he means it dont suck, but it probably also dont make pressure, so your dynamic timing advance is not good anymore, that will result in a retarted timing when the revs go up  :wink:  a lift pump is no problem as long it dont make high pressures
Greetz, Benjamin
Must make +250hp
Reply #5March 02, 2008, 07:39:12 pm
AudiVWguy
Electric Fuel Pump
« Reply #5 on: March 02, 2008, 07:39:12 pm »
OK,
So what is a good pressure range for the lift pump?
Also, does this make the IP last longer (not have to work as hard)?
Are there performance advantages with it or fuel milage advantages?
Any preferred brands to look for?
-JB
Reply #6March 03, 2008, 12:21:27 am
Benjamin
  • 485
Electric Fuel Pump
« Reply #6 on: March 03, 2008, 12:21:27 am »
Quote from: "AudiVWguy"
OK,
-JB
you dont NEED a lift pump, the internal pump dont need to work so hard, there is probably also less friction on the shaft, but i dont believe this is a great difrence, other say, a difrence is a difrence (for those who run a TDI with 12mm)
I think a pump from 1a2bar or less is good.
Greetz, Benjamin
Must make +250hp
