Author Topic: Need Boost Sooner  (Read 6093 times)
Reply #15February 26, 2008, 04:09:44 pm
Tintin
  • 1279
Need Boost Sooner
« Reply #15 on: February 26, 2008, 04:09:44 pm »
Quote from: "andy2"
I ran these turbo's back to back and the k24 spools a bit quicker than the T3.The k24 has a slightly bigger compressor than the T3 and the T3 has a noticably bigger Turbine than the k24.Beacuse the T3 has a bigger turbine it works better for mid range-top end performance and the k24 will provide better low-mid range performance.Both turbos are not efficent when pushed past 21 psi for k24 and 23psi for the T3.
+1  I already try both turbo on AAZ, T3 and K24 (from 1.6TD) and yes the K24 spool a bit quicker.
Reply #16April 14, 2008, 04:36:12 pm
KTZed
  • 170
Need Boost Sooner
« Reply #16 on: April 14, 2008, 04:36:12 pm »
Just thought I'd update this as I have now done the following:
-Turned boost pin to max ramp
-Cut nylon washer in half
-Turned starwheel down 2 turns
-Unscrewed smoke screw untill it was just touching the top of the pin
-Turned max fuel screw in ~1/4 turn
-Adjusted idle screw to normalize idle
Results:
-Awesome
Turbo spools WAY faster now. I get a nice smokey cloud up untill 10-15psi then it clears up as boost builds to 20psi. Max egt's are about 1500F under a long pull, creeping towards 1600 if I do repeated pulls and heat soak the IC.
All this being said...its not like I have no turbo lag. The engine still needs to be in its midrange (dont have a tach) to make full boost, and even in the upper rpms, it takes a moment to build. It is still not a quick spooling as my friends '96 AAZ with K14/K03 (not sure which).
It is a huge improvement over what it was though.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #17April 14, 2008, 05:15:08 pm
Need Boost Sooner
« Reply #17 on: April 14, 2008, 05:15:08 pm »
yeah i was going to say its definitely the fueling, under stock fueling i could never get more than 15psi.  its amazing how much power the lda adds
Reply #18April 14, 2008, 09:27:22 pm
DonGTI
  • 172
Need Boost Sooner
« Reply #18 on: April 14, 2008, 09:27:22 pm »
any news re. MPGs? have they improved?
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #19April 14, 2008, 10:15:56 pm
KTZed
  • 170
Need Boost Sooner
« Reply #19 on: April 14, 2008, 10:15:56 pm »
MPG have been affected minorly. My odometer doesnt work but I drive almost exactly the same amount each week (put in exactly 32L per week for the previous month or so) and this last week since I did the mods I put in 35L. That was including my first day of autocross in the golf however so im sure that burned some fuel. Overall I couldnt be happier.
Reply #20April 14, 2008, 10:57:00 pm
Need Boost Sooner
« Reply #20 on: April 14, 2008, 10:57:00 pm »
Those are kind of high EGT's, at least higher than I would run..
Reply #21April 14, 2008, 11:00:18 pm
truckinwagen
  • 1895
Need Boost Sooner
« Reply #21 on: April 14, 2008, 11:00:18 pm »
yeah, I try to stay under 1200F
but then I turboed an N/A
83 Opel Kadett Diesel
Reply #22April 15, 2008, 03:09:11 am
Riverfurm
  • 122
Need Boost Sooner
« Reply #22 on: April 15, 2008, 03:09:11 am »
If I want to make more smoke the boost will come on sooner but, it soots up the rear of the car. I just hate the offline performance. A small amount of boost in first, second almost full boost at 3800rpm(20 psi) 3rd, 4th and 5th full boost from 3000 rpm up. So when I pull away from a light the traffic passes me, by the time I hit 3rd gear I am passing them with some smoke. Exhaust temps rarely get above 1050 F. I use this car as my shop vehicle. It has about 200 pounds (don't know what that is in Kilos) of tools and parts. Best MPG was 40+ highway.But it is still fun to drive.
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #23April 15, 2008, 08:22:43 am
KTZed
  • 170
Need Boost Sooner
« Reply #23 on: April 15, 2008, 08:22:43 am »
Quote from: "jimfoo"
I suppose...but my car has always run hotter than others on here it seems...it was running this hot completely stock (stock boost, fueling, exhaust, no IC etc.). It will run at 1200F just holding speed up a small incline at hwy speed (making NO smoke). I have yet to check the timing so maybe that has something to do with it but it starts/runs fine so I never really bothered.
Also, when I say 1500F on a long pull, it'll only get there in 4th or 5th if I do a drag race start from 1st, or have a long stretch of hwy and pull up to 150kph or so...which really never happens during daily driving so im not too concerned. Ive yet to read anywhere of someone melting/blowing "X" part at "Y" Deg F EGT, its all just random claims of peoples comfort levels so untill I melt a piston Im happy  :twisted:
Reply #24April 15, 2008, 03:09:37 pm
Riverfurm
  • 122
Need Boost Sooner
« Reply #24 on: April 15, 2008, 03:09:37 pm »
When I  was drag racing snowmobile I ran an egt gauge and when it hit 1200F I knew the pistons where getting soft so I backed off it for a second and the temps. dropped down. If it hit 1500F that was a major melt down.
Reply #25April 16, 2008, 05:21:40 am
saurkraut
  • 904
Need Boost Sooner
« Reply #25 on: April 16, 2008, 05:21:40 am »
Quote from: "libbybapa"
An appropriately sized vnt turbo will offer virtually instant boost and yet better flow than a conventional turbo at higher flow/rpms.  The downside is the added complexity of an adequate vane control system and completely custom installation.
Andrew
Any chance of you offering a Vane Control System kit?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
