Author Topic: which nozzle: DNOSD 274 (GTD) or DNOSD 261 (MB)?  (Read 8744 times)
January 08, 2008, 01:32:03 am
zaprzal
  • 160
    • turbodiesel.pl
« on: January 08, 2008, 01:32:03 am »
which nozzle is better for IDI engine with some performance mods: stock GTD 274 or Mercedes 261, and why? Any other nozzles?
some people says that it MB nozzles aren't any better than stock VW and have spraying designed for different head, is it true?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1January 08, 2008, 07:28:09 pm
OM617
« Reply #1 on: January 08, 2008, 07:28:09 pm »
Mercedes uses a precombustion chamber while VW is more of a swirl chamber. MB has the fuel striking a ball to completely atomize.
Reply #2January 09, 2008, 12:26:29 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #2 on: January 09, 2008, 12:26:29 am »
Quote from: "OM617"
is it better to use mercedes or GTD nozzles on 1.6?
Reply #3January 09, 2008, 06:14:52 am
OM617
« Reply #3 on: January 09, 2008, 06:14:52 am »
GTD, AAZ nozzles would probably also do well.
Reply #4January 09, 2008, 09:08:23 am
saurkraut
  • 904
« Reply #4 on: January 09, 2008, 09:08:23 am »
I have the GTD nozzles in my 1.6.  If you feed them more fuel, they are better than the stock nozzles.
I haven't heard anyone saying that the Mercedes nozzles work good, or even have compared the Mercedes nozzles to the GTD nozzles.
In summary:
GTD nozzles work
Mercedes nozzles?????
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5January 09, 2008, 09:25:42 am
carrizog60
  • 978
« Reply #5 on: January 09, 2008, 09:25:42 am »
i have them but as i put them at the same time that other things i cant say the diference...
when i get my pump to deliver fuel the way it was before then i could tell the diference...
Portugal
Reply #6January 09, 2008, 10:39:53 am
« Reply #6 on: January 09, 2008, 10:39:53 am »
Dave @ PP is running Merc on his Frankin engine I believe.
Someone should ask..
I know he has said he has seen a good increase in power with the Merc tips.
Reply #7January 09, 2008, 02:42:38 pm
Tintin
  • 1279
« Reply #7 on: January 09, 2008, 02:42:38 pm »
merc 261 nozzle are around 0.10mm bigger than the GTD one and have a different spray.
I install some of these, and Im not sure if It's good,  for sure that give more power, but with much more smoke.
Reply #8January 09, 2008, 05:44:45 pm
« Reply #8 on: January 09, 2008, 05:44:45 pm »
Quote from: "Tintin"
Ah Tintin.. a piece of the holy grail... is that something found on ESI, or do you have another source for nozzle knowledge ??
Reply #9January 09, 2008, 05:50:01 pm
Tintin
  • 1279
« Reply #9 on: January 09, 2008, 05:50:01 pm »
no, It's not from esi, It's from another source that I does not know if it's credible, except that I measured myself with the means which I have, and that seems plausible.
Reply #10January 09, 2008, 05:57:20 pm
« Reply #10 on: January 09, 2008, 05:57:20 pm »
thanks for the response... the search for the secret decoder ring to DNO nozzles continues... !!
Reply #11January 09, 2008, 05:59:51 pm
Tintin
  • 1279
« Reply #11 on: January 09, 2008, 05:59:51 pm »
Quote from: "Vincent Waldon"
What you want to say by  "decoder ring" ?
Reply #12January 09, 2008, 06:05:09 pm
« Reply #12 on: January 09, 2008, 06:05:09 pm »
I'm referring to a definitive source of the parameters of the DNO series of nozzles... DNO SD XXX... in terms of flow, etc.
Reply #13January 09, 2008, 06:05:36 pm
935racer
« Reply #13 on: January 09, 2008, 06:05:36 pm »
I don't have MB nozzles in currently, just stock 1.6td nozzles, I am upgrading to the custom set of nozzles that Jake had made a couple years back that were originally intended for Mark's franken engine. I will upgrade the nozzles sometime in the next month or so. But yes the MB nozzles do give more power, and more smoke. I compared the spray patters of both on my pop tester and honestly the shape is damn near the same in the first inch and  half, which is all that matters for our eninges, at least thats how I remember it, that was about 2-3 years ago :?:
Reply #14January 09, 2008, 06:16:57 pm
Tintin
  • 1279
« Reply #14 on: January 09, 2008, 06:16:57 pm »
The end of the merc nozzle pintle are a different shape than the GTD one, I does not remember exactly wich It's different, but one have a more angle design and the end is more short, It's sure that change the spray.
