Author Topic: will kkk turbo bolt up to the quantum manifold?  (Read 5041 times)
May 30, 2004, 01:46:43 pm
purvisgs
  • 45
« on: May 30, 2004, 01:46:43 pm »
Hi, Im still looking into finding a td for my vanagon, and was just wondering if the kkk turbo will bolt up to the quantum manifold?
A bit of machining would be possible...
Also is the position of the turbo its self similar? (ie do you think that by using the kkk instead of the garett I would run into trouble with clearances?)
Thanks!
Reply #1May 30, 2004, 03:54:26 pm
Dr. Diesel
  • 1341
« Reply #1 on: May 30, 2004, 03:54:26 pm »
I have a longitudinal engine TD exhaust manifold. it's the same bolt pattern/flange as my jetta's k24 transverse engine exh. manifold.
