Author Topic: Adding oil squirters?  (Read 22144 times)
Reply #15December 17, 2007, 01:09:14 pm
dillenger1
  • 777
« Reply #15 on: December 17, 2007, 01:09:14 pm »
yes i am also interested in the BMW squirters $40.00 sounds better then $100.00.Do you know the ebgine type?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #16December 17, 2007, 02:14:23 pm
socalsean
  • 25
« Reply #16 on: December 17, 2007, 02:14:23 pm »
Quote from: "dillenger1"
I forgot. Just give the dealer the above mentioned part number.
Reply #17December 17, 2007, 05:37:51 pm
Gearhead
  • 87
« Reply #17 on: December 17, 2007, 05:37:51 pm »
That kit on Turbobricks.com (ha ha...) is bad a$$.  Any machinists around here want to fab up something for us?  I'll trade you some time with my valve shim kit & tools for some time with your squirter installer.
Don't the VW squirters have pressure valves in them so that they are only squirting when oil pressure goes up?  Do the BMW units?
'82 2 Door 1.6N/A :( Rabbit  '85 Cabrio project
Reply #18December 18, 2007, 10:27:47 am
socalsean
  • 25
« Reply #18 on: December 18, 2007, 10:27:47 am »
Quote from: "Gearhead"
That's pretty slick, eh? The community over there kicks ass!
I'm pretty sure the BMW squirters have a check ball as well.
Reply #19December 18, 2007, 12:09:16 pm
shegel
  • 312
« Reply #19 on: December 18, 2007, 12:09:16 pm »
this thread is awesome.....i dont think i trust myself enough to do the work though
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #20December 21, 2007, 05:24:38 am
Gearhead
  • 87
« Reply #20 on: December 21, 2007, 05:24:38 am »
Well, looks like it's going to be time to pull out the ole drill sooner than I thought.  My head gasket just started giving me a little pressure in my cooling system on the highway.  So, I'll rebuild, and If I'm in there, I figure it's time to add squirters.
Reply #21January 07, 2008, 08:01:17 pm
Gearhead
  • 87
« Reply #21 on: January 07, 2008, 08:01:17 pm »
Bump.   Does anyone have pics of factory squirter installation?  Are they the same as the BMW units?
Reply #22January 07, 2008, 08:39:54 pm
Baselyne
« Reply #22 on: January 07, 2008, 08:39:54 pm »
Are there any other differences between the Td piston and the N/A piston besides the notch for the oil squirter?
This thread is really amazing, I hope to coat piston tops and drill in the squirters someday
This is really something..Great job man!
Reply #23January 07, 2008, 08:59:33 pm
« Reply #23 on: January 07, 2008, 08:59:33 pm »
Quote from: "Baselyne"
supposedly the TD pistons have a special heat reflective coating, and may be made of a more heat resistant alloy...  my guess is that early on this was the case, and then VW just stuck to using the stronger piston for both TD and N/A.  would be interesting to know for sure though!
Reply #24February 02, 2008, 09:58:11 am
Fionn
  • 24
Squirters
« Reply #24 on: February 02, 2008, 09:58:11 am »
Well I finally received my squirters (well actually only one squirter and bolt so far, but enough to let me drill the holes).
I'm just wondering if anyone has some dimensions on how deep the cut in to the piston skirt needs to be?
Reply #25February 02, 2008, 01:24:06 pm
CoolAirVw
  • 175
Re: Squirters
« Reply #25 on: February 02, 2008, 01:24:06 pm »
Quote from: "Fionn"
I got a piston out right now.  I'll take some pics and measurements and post the results tomorrow, no wait, superbowl, monday, no wait got plans, tuesday (I'll try anyway)
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #26February 02, 2008, 01:43:57 pm
Fionn
  • 24
« Reply #26 on: February 02, 2008, 01:43:57 pm »
Cheers for that, I'll hopefully be busy drilling and tapping for the squirters tomorrow anyway ;)
Reply #27February 10, 2008, 03:29:12 pm
mtnsammy
  • 97
« Reply #27 on: February 10, 2008, 03:29:12 pm »
Thanks to libbybapa here is the bus depot listing.
Jet $22.72 068103157D
Reply #28February 10, 2008, 05:09:47 pm
skifree
  • 32
« Reply #28 on: February 10, 2008, 05:09:47 pm »
Vwdieselparts.com has oil squirters in stock for $25. each.
Reply #29February 11, 2008, 07:40:07 am
myke_w
  • 1099
« Reply #29 on: February 11, 2008, 07:40:07 am »
Since our squirters have a side bolt holding them in, drilling the block is a bit more involved.
"I'm pretty sure the BMW squirters have a check ball as well."
Can anyone confirm that the bmw style squirters have a check balll???
