Author Topic: 1.6TD oil squirter location  (Read 5817 times)
November 20, 2007, 12:41:24 am
Fionn
  • 24
« on: November 20, 2007, 12:41:24 am »
Hi,
    I want to add oil squirters to the block of my Mk2 (86, JP Code) 1.6 NA block while I'm doing a rebuild.
I was just wondering if someone could give me an indication of where exactly I need to drill and tap and / or any additional info that might be relevant while I'm at it.
Thanks,
Fionn.
Reply #1November 20, 2007, 04:38:00 am
« Reply #1 on: November 20, 2007, 04:38:00 am »
planning on turboing?  turbo's have bigger oil pumps too.  it helps cope with the extra oil flow.
not sure how to explain where they are... i'm sure someone has a pic
Reply #2November 20, 2007, 06:46:30 am
subsonic
  • 1836
« Reply #2 on: November 20, 2007, 06:46:30 am »
The squirters are for additional cooling.  You could also achieve the same thing by ceramic coating the piston tops.  That might be a easier cheaper option.
Reply #3November 20, 2007, 08:02:06 am
myke_w
  • 1099
« Reply #3 on: November 20, 2007, 08:02:06 am »
You'd likely need a TD block to use as a template to get the angles, drill depths, and positions correct, the squirters could also be sources from a 9a 16v block or an OBD1 2.0 ABA block. You'd almost certainly need to involve a machine shop.
Reply #4November 20, 2007, 08:52:30 am
Eli
  • 17
« Reply #4 on: November 20, 2007, 08:52:30 am »
Quote from: "myke_w"
Agreed.
But also, Heres a crappy quality pic to give you an idea:
EDIT: Oh yeah, I should note that this is a pic from a D24T, and I think the oil squirter setup is slightly different. Sorry, I didn't think of this before.
Goodluck.
-E
How fast?
As fast as it takes.
Reply #5November 20, 2007, 04:02:26 pm
Fionn
  • 24
thanks
« Reply #5 on: November 20, 2007, 04:02:26 pm »
Thanks for the photo man, it's a great help. I have a spare n/a block so I might do a bit of um, experimentation with a drill bit ;)
Reply #6November 20, 2007, 06:14:57 pm
CoolAirVw
  • 175
« Reply #6 on: November 20, 2007, 06:14:57 pm »
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #7November 26, 2007, 06:55:16 am
danfromsyr
  • 13
« Reply #7 on: November 26, 2007, 06:55:16 am »
but you would also need the TD pistons, they are notched to miss the Oil squirters.
Dan
Reply #8November 26, 2007, 08:53:17 am
Fionn
  • 24
notches
« Reply #8 on: November 26, 2007, 08:53:17 am »
How big is the notch? Anyone got a pic of a td piston skirt?
Reply #9November 26, 2007, 08:02:27 pm
CoolAirVw
  • 175
« Reply #9 on: November 26, 2007, 08:02:27 pm »
Wasn't taking a picture of the notch when I took this pic.
75 Porsche 914
93 GMC Truck
