Author Topic: too fast now 8-))  (Read 4840 times)
October 31, 2007, 12:37:00 pm
bert
  • 423
too fast now 8-))
« on: October 31, 2007, 12:37:00 pm »
Right boys,before the tax runs out tonight on the GTD i took it for a razz,got to say well impressed with it,no intercooler either.Its a AAZ with a T3 turbo,2.5" exhaust and the fuel screw is still SEALED.
The only thing i did was to grind the aneroid pin to give it a bit more power,this mod was amazing,it flies,no really flies,the timing is set to 0.95mm and starts 90 degrees crank rotation  :wink:  so its set up ok,
The aneroid pin is a bigger diameter than the 1.6TD pin so i had to grind the AAZ pin, today i scrapped a rover 220TD with a broken belt at 95mph,noticed the Bosch ve with the spaceship on top so i took the oin out,WOW,what a pin,larger AAZ diameter,and a cone that tapers so fierce it nearly leaves no metal at the top of the cone,needless to say,it went in my GTD this afternoon,wow,even better than my home made pin,and it seems to be a smoother power build than before,it even spun the tyres in 3rd gear too,
Now the question,without altering anything but the aneroid why is it so quick,im peaking at 11 psi,still have the cast downpipe on,no porting etc,i have the pump number here,its a brand new bosch fitted just before i cut the mk3 up for the lump,can you check it to see if its the right one anybody?   0460 494 346
Cheers Bert
Reply #1October 31, 2007, 01:53:26 pm
xud9te
  • 88
too fast now 8-))
« Reply #1 on: October 31, 2007, 01:53:26 pm »
Fitted to all manner of 1.9 td's from seat cordoba to VW vento.  Is the engine 1.6 or 1.9?
Reply #2October 31, 2007, 02:09:28 pm
bert
  • 423
too fast now 8-))
« Reply #2 on: October 31, 2007, 02:09:28 pm »
Its a 1.9 AAZ and its way quicker than expected,took a fellow dubber for a rasp and he was amaized,told me to slow down  :wink:
Bert
Reply #3October 31, 2007, 09:11:44 pm
too fast now 8-))
« Reply #3 on: October 31, 2007, 09:11:44 pm »
the boost pin can add quite a bit of fuel :)  a very good way to increase economy while off boost and power when you want it :)
Reply #4November 01, 2007, 12:49:55 am
bert
  • 423
too fast now 8-))
« Reply #4 on: November 01, 2007, 12:49:55 am »
i cant believe how livley these engines can be with such a tiny mod  :twisted:
Bert
Reply #5November 01, 2007, 04:19:31 am
xud9te
  • 88
too fast now 8-))
« Reply #5 on: November 01, 2007, 04:19:31 am »
Bert,
Had the fuelling maybe been altered before the pump came off the last engine?
Could you do a pull in 4th gear between 2 and 4000 rpm so I can guess the power?
Reply #6November 01, 2007, 11:59:30 am
bert
  • 423
too fast now 8-))
« Reply #6 on: November 01, 2007, 11:59:30 am »
xud,i cant use it now due to the road tax running out,the fuel is standard,the car was an old gents,it had a vw exchange engine fitted,a brand new bosch pump,then it failed the mot on loads of corrosion,the engine is as new with the tdi crank in it,the pump has not been touched,the fuel screw cap is still on,i havent done a governor mod,top still sealed,ive just swapped the aneroid pin,thats all,my mate cant understand why it pulls so well,even up to redline,the power keeps coming it dont die off toward top revs,suits me sir  :wink:
Bert
Reply #7November 02, 2007, 10:50:58 am
rov716y
  • 96
too fast now 8-))
« Reply #7 on: November 02, 2007, 10:50:58 am »
is this the red one you brought to gaydon mate?
or a new project?
i was busy at gaydon or i would of let you take me for a spin in it
Reply #8November 02, 2007, 01:41:03 pm
bert
  • 423
too fast now 8-))
« Reply #8 on: November 02, 2007, 01:41:03 pm »
Ye rov the burgundy one,its quicker now with the rover pin fitted  :wink:
Bert
Reply #9November 02, 2007, 01:46:10 pm
numbnuts
  • 99
too fast now 8-))
« Reply #9 on: November 02, 2007, 01:46:10 pm »
Quote from: "bert"
Bert
Think i might have to try this pin aswell! Whats it out of?
Reply #10November 02, 2007, 01:58:12 pm
bert
  • 423
too fast now 8-))
« Reply #10 on: November 02, 2007, 01:58:12 pm »
The pins from a rover 420 220 620 TD about a n reg  :wink:
Bert
Reply #11November 02, 2007, 02:31:07 pm
numbnuts
  • 99
too fast now 8-))
« Reply #11 on: November 02, 2007, 02:31:07 pm »
so do u think i can do this without any other mods? I have left it alone since i got it!
Reply #12November 03, 2007, 08:18:45 am
bert
  • 423
too fast now 8-))
« Reply #12 on: November 03, 2007, 08:18:45 am »
Its got to be worth a try,ive not touched any other part of the pump,the only thing ive got is a T3 turbo and a 2.5" stainless exhaust,and the pump set to 0.95 instead of .85 so it starts better when hot  :?
Bert
Reply #13November 03, 2007, 03:42:34 pm
numbnuts
  • 99
too fast now 8-))
« Reply #13 on: November 03, 2007, 03:42:34 pm »
I'll keep an eye open for one of them then :wink:
Reply #14November 08, 2007, 11:54:21 am
rabfan
  • 28
too fast now 8-))
« Reply #14 on: November 08, 2007, 11:54:21 am »
Start collecting pins and send them over to us in Canada!
Very interested.
RJ
