Author Topic: Oil filter, relocate and cool?  (Read 3154 times)
September 03, 2007, 06:23:12 pm
patracy
  • 142
« on: September 03, 2007, 06:23:12 pm »
I'm trying to think something ahead on my project.  Anyone know where I can get a kit to angle the oil filter back.  (It appears that a quantum uses a swept angle adapter) Or relocate it all together?  The engine mounts I'll be using will interfere with the filter.  I also need to install a cooler too.  I was thinking about just using one of the "universal" oil filter relocater and adding a air/oil cooler inline with it as well.
Anyone did anything like this before?  I know the turbos use a sandwich oil/water cooler mounted to the filter adapter.
Reply #1September 03, 2007, 08:19:50 pm
westcoaster
« Reply #1 on: September 03, 2007, 08:19:50 pm »
http://www.acmeadapters.com/store_engine.php#indparts
Anyone swapping a vw diesel into a suzuki samurai needs the angled oil filter bracket. I don't think it comes with the oil cooler attached though.
Acme adapters manufactures a kit to swap the diesel into the samurai. The angled filter bracket is one of the parts listed as a separate sale item.
Oil Filter Housing (1.6) $55
Oil Filter Housing (1.9) $135
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #2September 03, 2007, 09:32:33 pm
QuickTD
  • 1156
« Reply #2 on: September 03, 2007, 09:32:33 pm »
The oil filter used on the VW diesel has the same physical dimensions, thread pitch gasket size etc. as a ford PH8 oil filter, so any relocate kit for a ford V8 should work fine on the VW.
