Author Topic: best / most efficient intercoolers? How to tell?  (Read 2498 times)
August 30, 2007, 01:22:16 pm
myke_w
  • 1099
« on: August 30, 2007, 01:22:16 pm »
Can we get a list of the best / most efficient inter coolers going? I'd be interested in air - air and air - water applications.
Also any information that helps to determine efficiency would be useful..
Reply #1August 30, 2007, 04:26:02 pm
xud9te
  • 88
« Reply #1 on: August 30, 2007, 04:26:02 pm »
Well, you would have to test each 'cooler in the specific application (or one application for all tests) to achieve a satisfactory comparison.
Basically if a 'cooler is over 80% efficient and has less than a 8% pressure drop accross it, then its a good one for the application (discounting charge volume - i.e. as long as its not too big).
Testing for temp is simple.  Insert a k-type thermocouple before and after the IC and record the temp drop.
Testing for pressure needs a boost guage connected before and after the IC.  Without making an adapter that fits in the IC hoses with a fitting for a pressure reading, the compressor output and any manifold pressure connection (LDA?) can be used, but his will also record pressure drop in the intake piping.
Reply #2August 31, 2007, 12:57:46 pm
myke_w
  • 1099
« Reply #2 on: August 31, 2007, 12:57:46 pm »
is there a particular range of inter coolers that are best when used in our applications? I have a massive Volvo inter cooler, but it seems like that would cause way too much lag, I also have a smic from a tdi and it' seems pretty small, maybe too small to make any difference..
Reply #3August 31, 2007, 01:22:32 pm
« Reply #3 on: August 31, 2007, 01:22:32 pm »
Quote from: "myke_w"
a small intercooler can be great on our cars.  the only issue is getting enough airflow to take the heat away.  you can use a fan, a hood scoop, or some even use misting systems to help dissipate heat.
if you can fit the volvo intercooler, i think the cooling capacity will offset the increase in turbo lag.  one thing that will most definitely increase turbo lag, is a set of really badly placed intercooler pipes and some sharp bends.
Reply #4September 01, 2007, 05:42:21 am
nogama3
  • 162
« Reply #4 on: September 01, 2007, 05:42:21 am »
i have an intercooler fitted to my aaz golf mk3 where it appears that it does not get much cooling :
i made a recent beach trip (150 miles) and when i got there i checked the temp of the pipes to and from the intercooler:
and the one from the turbo to the intercooler was very hot and the one from the intercooler into the inlet manifold was slightly warm and i was surprised on how effective the intercooler was.
i have managed to purchase a front mount intercooler from a sharan i beleive:
which should fit into the front bumper and should help cooling the air further.
