Author Topic: running without airbox, how bad?  (Read 5491 times)
August 28, 2007, 08:26:44 pm
Infinitrium
  • 151
« on: August 28, 2007, 08:26:44 pm »
So i was screwing around this afternoon and i took the top of the airbox off and took out the filter. i then thought it would bd cool to fire up the engine and take the car for a spin to see what it sounded like. wow, the turbo was so much easier to hear working. will i cause any damage by running a little while without the filter and airbox? well, aside from the obvious danger of imgesting dirt of course. is there anything i can do to be able to hear the turbo as easily as i can now but not run the risk of sucking in dirt? i was thinking maybe one of those cheap 30 dollar cone air filters from cadibn tire mounted onto the hose that goes into the airbox?
Reply #1August 28, 2007, 08:56:30 pm
Infinitrium
  • 151
« Reply #1 on: August 28, 2007, 08:56:30 pm »
My exhaust is detatched from a bit behind the cat converter, yeah, both mufflers are unhooked and in my trunj, does that count? :)
Reply #2August 29, 2007, 06:43:26 am
Darth Garry
  • 136
    • http://www.notinteresting.com
« Reply #2 on: August 29, 2007, 06:43:26 am »
I knew a guy on another forum that got the smart idea of running his air intake into the cabin.  He sure could hear the turbo then but realized he couldn't drive the car with the windows down or it would keep popping his ears.
Exhaust mods are the way to go.
Garry
All for one, and one for Awesomeness!
Reply #3August 29, 2007, 02:04:55 pm
Mk2Fanatic
  • 93
Re: running without airbox, how bad?
« Reply #3 on: August 29, 2007, 02:04:55 pm »
Quote from: "Infinitrium"
been using a cone style filter for six monthes...no regrets...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #4August 29, 2007, 08:09:35 pm
« Reply #4 on: August 29, 2007, 08:09:35 pm »
Even at idle, I hear my VNT just fine. 2.5" exhaust and even a muffler. I imagine your cat is what cuts your noise the most.
Reply #5August 29, 2007, 08:18:53 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: August 29, 2007, 08:18:53 pm »
Quote from: "jimfoo"
Yeah cats act as pretty good mufflers, especially if they are old and partly clogged. Take it off and enjoy the added power.
Reply #6August 29, 2007, 11:01:46 pm
Infinitrium
  • 151
« Reply #6 on: August 29, 2007, 11:01:46 pm »
No cat converter and no mufflers? Wow, wouldn't that be loud?
Reply #7August 30, 2007, 06:22:01 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #7 on: August 30, 2007, 06:22:01 am »
loud is when your driving up a mountain and your exhaust snaps off at the back of the extractors on your n/a diesel.... THAT was LOUD.
'91 Golf Cabrio 1.9TD
Reply #8August 30, 2007, 10:27:51 am
« Reply #8 on: August 30, 2007, 10:27:51 am »
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=8738033
Reply #9August 30, 2007, 12:44:20 pm
Infinitrium
  • 151
« Reply #9 on: August 30, 2007, 12:44:20 pm »
What was that loud whining sound?
Reply #10August 30, 2007, 12:59:53 pm
« Reply #10 on: August 30, 2007, 12:59:53 pm »
uh turbo  :roll:  :lol:
Reply #11August 31, 2007, 06:27:18 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #11 on: August 31, 2007, 06:27:18 am »
Just as a reference on how seriously the OEMs take this, if you do an initial startup without air cleaners connected on a Cummins or Detroit, you have just voided your warranty.
Calvin
91 VW Golf 1.6NA 5spd
Reply #12August 31, 2007, 01:18:23 pm
« Reply #12 on: August 31, 2007, 01:18:23 pm »
Quote from: "clbanman"
Yea verily.
Wonder what they do if you run with a flashing oil pressure light while telling yourself it must be the sensor ???!!!!! :roll:
(sorry... couldn't resist... any given day it seems like half the people on the Vortex gasser forums are trying to convince themselves they can't possibly have oil pressure problems... must be the wiring, or the sensor, or the wrong brand of oil !!)
Reply #13August 31, 2007, 02:13:43 pm
  • 656
« Reply #13 on: August 31, 2007, 02:13:43 pm »
Quote from: "Vincent Waldon"
Yea verily.
Well older cars arent that reliable electrically so people just tend to blame that instead of real oil pressure problem. I upgraded to a 36mm oilpump (which is standard on later MK2 TDs) and used 15w40 oil to get rid of the low oil pressure when the engine got hot. It patched the problem but I know the bearings inside the engine are worn and letting pressure out. I'll eventually have to replace them.
