Author Topic: Almost There!!!!  (Read 2822 times)
August 26, 2007, 11:52:38 am
Riverfurm
  • 122
Almost There!!!!
« on: August 26, 2007, 11:52:38 am »
Almost ready to swap out the 1.6 NA for a for a Turbo 1.6 in my 86 Golf.
Turbo engine is from a 85 Jetta with solid lifters and a Garret turbo with about 30,000 miles on it. So far it has a Giles pump, Passenger 3"down pipe,boost gauge,egt gauge(installed sensor before turbo), pop off valve on intake has been shimmed shut and a boost control valve.
PM items, valve adj.,pump timing,timing belt, water pump, belts, clutch & prs plate replace
Items left... block heater and likage kit for shifter and trip to the exhaust shop.
Can anyone think of something elese?????
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #1August 26, 2007, 12:21:46 pm
bert
  • 423
Almost There!!!!
« Reply #1 on: August 26, 2007, 12:21:46 pm »
Latex gloves keep your hands clean  :wink:
Bert
Reply #2August 26, 2007, 12:33:46 pm
Riverfurm
  • 122
Almost There!!!!
« Reply #2 on: August 26, 2007, 12:33:46 pm »
Got them...Plus prs. clean old engine :!:
Reply #3August 26, 2007, 12:51:40 pm
numbnuts
  • 99
Almost There!!!!
« Reply #3 on: August 26, 2007, 12:51:40 pm »
A nice set of brakes! :D
Reply #4August 26, 2007, 02:40:45 pm
Almost There!!!!
« Reply #4 on: August 26, 2007, 02:40:45 pm »
Everything good on transmission side.... both seals, clutch, pilot shaft seal, throwout bearing, flange bearings ??   Heck of a lot easier to change things now than later !!
Motor mounts in good shape ??
CV joints OK ??
Reply #5August 26, 2007, 04:32:43 pm
Black Smokin' Diesel
  • 656
Almost There!!!!
« Reply #5 on: August 26, 2007, 04:32:43 pm »
Good time to replace all the shifter bushings. It's a PITA to do with the engine in.
Reply #6August 28, 2007, 02:49:44 am
Riverfurm
  • 122
Almost There!!!!
« Reply #6 on: August 28, 2007, 02:49:44 am »
Allso have new motor and trans mounts. And shifter bushing kit coming.
