Author Topic: Power Steering  (Read 3168 times)
August 24, 2007, 01:19:38 am
MK2 GTD
  • 31
Power Steering
« on: August 24, 2007, 01:19:38 am »
Hello all  :)
I am in the process of sourcing all the bits and pieces required to fit power steering in into my R/H drive GTD.  Got most of the bits to do the conversion, the only thing I am lacking is the power steering reservoir, mount and pipe down to the T piece in the return pressure line pipe work.  I am told that due to there being an intercooler fitted on the GTD then the steering reservoir isn’t mounted on the chassis rail as on a standard petrol model.
Has any one got any under bonnet photos so I can see the location the reservoir is mounted.  Also if any one has a reservoir, mount, pipe and T piece going spare they would like to sell on.
This was diagram was taken from Vagcat.com, its for a L/H drive model but shows the pipe work, reservoir and T piece.
http://www.vagcat.com/epc/cat/vw/GO/1991/110/52/1091356/
Reply #1August 25, 2007, 05:38:10 pm
con
  • 106
Power Steering
« Reply #1 on: August 25, 2007, 05:38:10 pm »
Hey, I took some photos for you this evening, the resevoir is located under the intercooler. it's not a great place though IMO, hard to get to!
Goodluck and let me know how the PAS conversion works out, my friend is looking to do it on his mk2  :wink:
Reply #2August 25, 2007, 06:39:49 pm
patracy
  • 142
Power Steering
« Reply #2 on: August 25, 2007, 06:39:49 pm »
Might I change the subject slightly on this?  Where can I get a power steering pump and bracket that will bolt up to my 1.6?  I'd like to use the stock VW alt., retain the AC pump, and have a PS pump all on my engine for the swap I'm working on.
Reply #3August 25, 2007, 06:42:11 pm
Power Steering
« Reply #3 on: August 25, 2007, 06:42:11 pm »
most later mk2 TDs came with PS (unfortunatly) you shouldn't have a problem finding a used one
Reply #4August 25, 2007, 06:48:25 pm
patracy
  • 142
Power Steering
« Reply #4 on: August 25, 2007, 06:48:25 pm »
Quote from: "burn_your_money"
 Being in the US I will have a problem.  Guess I'll keep my eye open on ebay  Is there a setup I can use to adapt my current accessories and add the PS pump?
Reply #5August 25, 2007, 06:55:36 pm
patracy
  • 142
Power Steering
« Reply #5 on: August 25, 2007, 06:55:36 pm »
Is this what I need?
click here
Would it still work with my current alt and AC pump?
(Sorry to steer this thread away  :wink: )
Reply #6August 25, 2007, 08:52:17 pm
Power Steering
« Reply #6 on: August 25, 2007, 08:52:17 pm »
that looks like a mk2 pump.  personally i would rather change to mechanical steering... power steering is nice, but one more thing to break (and get in the way of when changing the t-stat)
Reply #7August 25, 2007, 09:08:20 pm
patracy
  • 142
Power Steering
« Reply #7 on: August 25, 2007, 09:08:20 pm »
Quote from: "jtanguay"
It's not going into a VW.  Power steering WILL be needed.  It's for a 4x4 suzuki samurai on 33" tires.
Reply #8August 25, 2007, 09:12:27 pm
Power Steering
« Reply #8 on: August 25, 2007, 09:12:27 pm »
Yes that is the proper pump. You'll need a different crank and WP pulley most likely. Just put a WTB on the forums, someone definitly has one. I just threw one out or I'd have one
Reply #9August 26, 2007, 01:32:37 am
MK2 GTD
  • 31
Mk 2 GTD power steering
« Reply #9 on: August 26, 2007, 01:32:37 am »
Con,
Thanks for thee photos  :) ,spoke to my mate who knows a VW parts man who checked it out for me, apparently the GTD,because of the intercooler set up, the reservo bottle is located on the N/S inner wing in the recess ibn the washer bottle as per photo below
click here
Hence the reason why your reservior is a s**t to fill up. Hopefully he has managed to find the bits i need.  I have a full Gti power stweering set up to use bits from.  The mounting on the GTD for the alternator / steering pump is completly differant from the petrol model, managed to get one of a GTD that was being broken.
