Author Topic: Plasma cut copper gasket attempt  (Read 5988 times)
August 21, 2007, 05:46:08 pm
flapjack
  • 283
« on: August 21, 2007, 05:46:08 pm »
the clean side
the slag side
I cut the T3 flange because in small quantities the copper ain't cheap. .043" x 12" x 12" is about $29 Also easier to change then a head gasket if it doesn't work.
I'm not too optimistic because my table doesn't move the torch fast enough for such thin material. I'm afraid in cleaning the slag and splatter I may destroy it.
signature
Reply #1August 21, 2007, 09:04:49 pm
blkboostedtruck
  • 1535
« Reply #1 on: August 21, 2007, 09:04:49 pm »
I've got a bunch of different tools for removing slag and deburing! do you want me to experiment? I'd be interested in a head gasket down the road! I'd be willing to try and remove the slag on that T3 coppergasket and send it back for you to inspect! I like challenges! whats the worst i can do if i screw it up i owe you 30 bucks! let me know? i'm sure i can do it with no problem for you!!
  thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 21, 2007, 10:22:54 pm
flapjack
  • 283
« Reply #2 on: August 21, 2007, 10:22:54 pm »
the $30 is for the whole 12x12 piece, so each T3 sized piece is maybe . . $5?
If you'd rather have a head gasket, all I need is an old one to copy
material cost might make it cheaper to get one from headgasket.com for $85
If you've got a gasket laying around, measure it and I'll tell you what i can get the copper for.
signature
Reply #3August 22, 2007, 06:06:28 am
fastvicar
  • 154
« Reply #3 on: August 22, 2007, 06:06:28 am »
I've got a Mitsubishi laser if you've got a .dxf file   :wink:
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #4August 22, 2007, 07:36:05 am
flapjack
  • 283
« Reply #4 on: August 22, 2007, 07:36:05 am »
nice!
i will try to draw it and get it up asap
signature
Reply #5August 23, 2007, 06:39:04 am
fastvicar
  • 154
« Reply #5 on: August 23, 2007, 06:39:04 am »
8)
Reply #6August 23, 2007, 06:54:45 am
Slave2School
  • 531
« Reply #6 on: August 23, 2007, 06:54:45 am »
I would pay to have somone make me a copper gasket for the BMW I bought.  It has the same engine as the 524TD has in it, maybe something a bit thicker to lower the compression a point :)
2002 ford focme wagon
Reply #7August 25, 2007, 10:50:35 pm
hillfolk'r
  • 1532
« Reply #7 on: August 25, 2007, 10:50:35 pm »
i asked the metal supply house  if he had any scraps large enough for "this",and i pulled out a paper gasket i had for mockup  t3 flange
i got 2 pieces of .040 for like 3$ (enough for 2)
then i used a dremel tool  to make the gasket
works great no leaks
Throttle cables ftw
Reply #8August 26, 2007, 06:45:02 am
Slave2School
  • 531
« Reply #8 on: August 26, 2007, 06:45:02 am »
Hmm, thanks Hill that should be something I could accomplish, probably easier than cross boarder shipping too.
Reply #9August 26, 2007, 11:30:22 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: August 26, 2007, 11:30:22 am »
I think I could do that with a couple of drill bits, a gimlet, a block of hard wood and some old wood chisels [and a Birmingham screwdriver] :lol:
Mark-The-Miser-UK
Reply #10August 27, 2007, 01:42:23 pm
Baxter
« Reply #10 on: August 27, 2007, 01:42:23 pm »
heh, birmingham screwdriver.
Mines called Larry, Larry the lump hammer.
 :lol:
If Larry can't shift it, nowt can.
 :shock:
Larry and Bertha are a formidable team..
(Bertha is a dirty gert 5 ft f**k off bar!)
Reply #11August 27, 2007, 03:08:59 pm
Mark(The Miser)UK
  • 1557
« Reply #11 on: August 27, 2007, 03:08:59 pm »
Quote from: "Mr Brick-Yard"
 :lol:
 :shock:
Ha ha, don't suppose that the Birmingham in America [in Mass. is it?] Ever got the Birmingham screwdriver :lol:
My 'Bertha' is a piece of quality scaffolding...
I still have a wheelie bin full of bottled water down here ... I was looking for some good recipes...
It's amazing what can be cut with a quality wood chisel.
Mark-The-Miser-UK
