Author Topic: glow plugs not glowing!!!!  (Read 3358 times)
August 10, 2007, 09:35:09 am
rov716y
  • 96
« on: August 10, 2007, 09:35:09 am »
if i directly connect 12v to them they work but not when i turn the key i can hear the (new)relay clicking in and out but there not getting hot!!!!!
the red and white wire in the back off the fuse board i dont know if its pluged in right its in the top left corner. there is a sapre plug at the back off where the relay sits is this right?
Reply #1August 10, 2007, 10:01:38 am
« Reply #1 on: August 10, 2007, 10:01:38 am »
follow the glowplug wire in the engine bay to the black box on the firewall, there is a 50a (or 60a I forget) amp fuse in there. If that is fine try removing the coolant temp sensor wire and then using the key, it may be reading that the engine is warm enough to not need glow plugs
Reply #2August 10, 2007, 02:34:20 pm
rov716y
  • 96
« Reply #2 on: August 10, 2007, 02:34:20 pm »
wow!!! simple
Reply #3August 10, 2007, 09:00:25 pm
« Reply #3 on: August 10, 2007, 09:00:25 pm »
problem solved?
Reply #4August 11, 2007, 12:13:48 am
Cheesetoast
  • 285
« Reply #4 on: August 11, 2007, 12:13:48 am »
i carry a spare one of these fuses in my glove box, they tend to blow at the worst times, stupid things are like $4 each at the dealer.
Reply #5August 12, 2007, 01:23:25 pm
rov716y
  • 96
« Reply #5 on: August 12, 2007, 01:23:25 pm »
fuse was fine!!!!
its the sensors (all off em) i dc'd
Reply #6August 13, 2007, 09:06:40 am
Demons UK
  • 21
« Reply #6 on: August 13, 2007, 09:06:40 am »
Where is this temp sensor?
on a GTD 1.6?
Reply #7August 13, 2007, 08:11:21 pm
« Reply #7 on: August 13, 2007, 08:11:21 pm »
I'm not positive about the GTDs but on the north american ones it's 1 of the 2 on the coolant flanges on the head, usually between cylinders #3 and #4
Reply #8August 14, 2007, 10:22:08 am
rov716y
  • 96
« Reply #8 on: August 14, 2007, 10:22:08 am »
its a 1.6 n/a
theres 3 sensors one on flange(between 3 and 4) one on pipe out for heater matrix and one next to it on end off block no idea which are which or wat cable goes where
