Author Topic: Greater than 20psi mods AAZ T3  (Read 14046 times)
Reply #15January 14, 2024, 08:43:48 pm
oblique
  • 317
    Diesel while you can.
Re: Greater than 20psi mods AAZ T3
« Reply #15 on: January 14, 2024, 08:43:48 pm »
Agreed but you still get net power gains at cost of even more economy and lifespan...per graph its diminishing returns after about 25psi.
I think the general consensus has been 15psi non intercooled would run with similarl longevity to factory, to simplify.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #16January 15, 2024, 07:15:06 am
  • 5104
« Reply #16 on: January 15, 2024, 07:15:06 am »
Oh definitely, no sweat. And the boost controller helps spool up significantly. It's night and day with a t3 even at 8psi
Reply #17January 19, 2024, 03:04:03 pm
oblique
  • 317
« Reply #17 on: January 19, 2024, 03:04:03 pm »
I did not know this...I thought the wastegate stayed closed completely until opening pressure (~11psi)...
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #18January 28, 2024, 08:21:02 am
  • 5104
« Reply #18 on: January 28, 2024, 08:21:02 am »
it doesnt, between the backpressure in the exhaust pushing on the wastegate valve, and the boost pressure pushing on the diaphragm they start to sneak open.
Reply #19January 28, 2024, 05:18:40 pm
  • Online
  • 2926
« Reply #19 on: January 28, 2024, 05:18:40 pm »
 I saw a utube video where the guy threaded a bolt into the plate near the exhaust
and used the bolt to hold the wastegate closed all the time.
 I don't think even he even got 20psi.
Reply #20January 28, 2024, 06:17:42 pm
  • 5104
« Reply #20 on: January 28, 2024, 06:17:42 pm »
it depends on fueling. my old 1.6 had a k24 with a wastegate that was stuck shut, and with stock fueling it would go to 15psi. by adding fuel i could get to 25-30psi totally controlled by fuel. fuel adds alot of exhaust volume/energy by turning into heat and combustion gases like co2
Reply #21January 29, 2024, 06:10:23 am
mstephenson
  • 47
« Reply #21 on: January 29, 2024, 06:10:23 am »
I have been reading about intercoolers.
"Maximum Boost", by Corky Bell
Two things regarding an intercooler:
1. To lower temps pushed back into engine
2. Try not to lower air pressure too much while doing #1.
I have a question...
IC Efficiency.
The goal of the intercooler is to drop the air temp back as close to ambient as possible (pg. 52-53).
T=Temperature
(air flow location)
T(ambient) = T(out of intercooler) = 1 = 100% efficient.
? by adding methanol spray after the T(out of intercooler) and prior to the engine, the temps could be less than T(ambient) resulting in an efficiency of >1 ?
Has anyone done this? experimented adding this? used methanol instead of IC? opinions/comments?
I live in Texas and the air on a road at a stop light in august is easily +135F getting sucked up.
Reply #22January 29, 2024, 09:43:47 am
  • 5104
« Reply #22 on: January 29, 2024, 09:43:47 am »
I prefer the use of an intercooler because there's nothing to refill. You also have to find a way to meter how much is sprayed into the intake. Air to air intercoolers are super simple, and an AWIC setup can be nearly 100% efficient.
I went to speed week last year and was part of Steve Menendez's record holding team salty frog (1.5td vw powered dodge rampage). He has a large AWIC setup on that car, and data logging. at nearly 35 psi the air temps at the turbo outlet were around 400F after the intercooler in the intake manifold they were 70 degrees; roughly ambient. The AWIC coolant reservoir was filled with ice, but still this is a very effective intercooler even without ice.
