Engine Specific Info and Questions => IDI Engine => Topic started by: KAC on August 03, 2007, 05:39:30 pm
Title: K26 turbo ?
Post by: KAC on August 03, 2007, 05:39:30 pm
K26 turbo are they worth putting on my 1.6td?
Title: K26 turbo ?
Post by: Vincent Waldon on August 03, 2007, 06:33:55 pm
What does your TD have now... Garrett T3 ?
Title: K26 turbo ?
Post by: KAC on August 04, 2007, 04:54:23 am
it use to...now it has another KKK (not sure of #) now...The K26 is off of a Audi 4000
Title: K26 turbo ?
Post by: D1ES3L on August 04, 2007, 08:59:06 pm
probably not... pretty sure the k26 has the additional coolant lines as well as the manifold flange being trapezoidial or vice versa.  Does that make sense??  Maybe you could swap internals to your k24 or t3 though.
Title: K26 turbo ?
Post by: Black Smokin' Diesel on August 04, 2007, 11:07:35 pm
You can make a k24/26 hybrid using the k24 turbine housing with the k26 compressor side. IIRC, the K24 uses k26 internals.
Title: K26 turbo ?
Post by: KAC on August 05, 2007, 04:25:56 am
Quote from: "D1ES3L"
I all ready made an adapter to the manifold...as for the coolant lines are no problem
Title: K26 turbo ?
Post by: dillenger1 on January 08, 2008, 05:12:31 pm
I may be getting a #6 k26 from an audi 5000.I would like to know if it will spool up.It seems like its on the large side.What can be done to help with lag?I have the engine completely disassembled.
Title: K26 turbo ?
Post by: subsonic on January 08, 2008, 08:07:17 pm
No experience, but from reading here, people have stated it would be a lag monster.  Too big.
