Engine Specific Info and Questions => IDI Engine => Topic started by: the4ork on July 11, 2007, 09:57:31 am
im just wondering since most of us should be running 020's and alot of you guys are running higher than stock boost....
Running 24 PSI with pleanty of smoke.
I toasted one last year. it didn't blow up, but it just got louder and louder in all gears till it sounded like it was going to hatch and i pulled it.
The thing didn't leak, shifted just fine, and was still full of Redline MTL.
But something in there wanted out....
A bolt kit would prevent most of the issues youd see from added power, they used 020's with ABA's and 9a 16v's which kick out more power stock than most of our machines do on a good day. Bolt kit and you are set, then you only have to worry about tearing axles up : :twisted:
the idi's wont really hurt gearboxes, even turned up
but the tdi-m i have has broke 2 or 3 boxes in about a year and a half
The 020 isn't known for it's sturdyness but it'll hold at least 200hp being abused. Think about installing a bolt kit and a limited slip diff along with a good clutch (8v clutch disc with 16v pressure plate is plenty for a mildly tune TD, it'll hold 170hp easely).
If you're really scared of breaking trannies, swap an 02A in. The only downsides are that it's hydraulic and cable shifted (although there is a conversion kit available in europe to convert to good old rods and levers).
I think it's the torque that kills them, not the HP
I don't have numbers though
What's a bolt kit, and where do you get one? I heard someone at the local VW shop mentioning it to a customer over the phone once.
The differential inside of the 020 is held together with rivets. With stock power levels they are no problem but increased power can cause the rivets to shear off. The result is the diff starts machining itself through the side of the case.
The bolt kits you heard mentioned replace the problem rivets. The bolt kit should allow the transmission to handle increased power safer.
I would love cable shift and hyd clutch!
Just to put in my tuppence worth.
Stock 80hp gtd, 150,000 miles, unwelcome bid for freedom by said rivets. If it was me, and I had to gut a gearbox anyway, bolt kit would be on the list. Seen plenty in the scrapyard die this way. Rivets must save VW pennys on each car. Don't wound a problem, kill it, dead. :twisted:
The rivets work themselves loose after miles or abuse and eventually one lets go and comes through the case and that's all she wrote, if you have an 020, you need a bolt kit, there's no two ways about it, eventually given enough miles, they all do it .
i had an aba turbo with 242 ft. lbs of torque... never broke the tranny but i blew a third of a piston away :P
So you just replace the rivets with any old bolt that will fit it? or is there and actual "kit" with all the right sized bolts etc.?
Don't use anything else than a kit.
http://www.germanautoparts.com/Volkswagen/Jetta/Transmission/69/2
I havent broken one from abuse just old and loose transmission once. I didnt want to risk it when going to the TDI-M so I got a 02A from a 98 Beetle for the TDI and the cables and hydrallic clutch are awesome in my opinion but I can see where in racing you might not like it, but once you get used to it its great, I only have 10 psi running through my tdi right now just got it running yesterday with boost and all I can say is WOW :shock:
this 1.9 TDI-M giles pump equipped with 10 psi (need to adjust the variable gate to get more boost) kicks the crap out of my old 1.6 idi with 25 psi and no boost aneroid
I have heard of guys breaking 90mm cv joints though whe the power and torque are turned way up
later
Justin
later
Justin
How much power do you need for that? I had no troubles with 90mm cv joints in Audi (180hp/300nm) Maybe I did not have enough grip to break those? :lol:
where can one get this kit? i'm getting mine changed this week :o
VM Autohaus should have them, that's where they were discussing them.
later
Justin
my 90mm cv's are holding in there just fine on my tdi-m,and they are orig to the car with about 120k on them
its not usually the cv's that are a problem,,its the transmissions
put slicks on and start breaking eveything though :wink:
thats what is probably saving me a little,is excessive wheelspin
oh well at least it gets goin good in the later part of 3rd gear when it has better traction
I broke motor mounts in the first start with slicks :lol:
those break easy without slicks :lol: :lol: :lol:
