Engine Specific Info and Questions => IDI Engine => Topic started by: larry104 on June 07, 2007, 09:45:38 am
Title: smoke screw questions
Post by: larry104 on June 07, 2007, 09:45:38 am
What physically does the smoke screw do in the injection pump?  I'm guessing it adjusts the starting position of the tapered valve. I undersand the star wheel adjusts diaphragm spring tension.  If I want less smoke when I spool up the turbo,  which way do I turn the screw and by how much? What is a typical amount of adjustment?   T hank you.
Post by: Hillshy on June 07, 2007, 04:15:59 pm
Hi Larry,
this was provided by Trev0rbr,
ok so here is the star wheel, the spring sits in it and it adjusts the tension on the spring, turning it to the left raises star wheel and the springs seat, this increases tension, turning it to the right lowers the star wheel and decreases tension, which increases fuel, as you can see i put marks on this as well so that it is much easier to see how many times i turned it
i really useful link, a good read.
Post by: Hillshy on June 07, 2007, 04:19:55 pm
http://www.vwdiesel.net/phpBB/viewtopic.php?t=645&start=0&postdays=0&postorder=asc&highlight=
heres the link with pics
Post by: RabbitJockey on June 07, 2007, 08:04:28 pm
it is well known that i am a pimp
Post by: Hillshy on June 09, 2007, 02:15:32 am
oook then,
so I hope that it was ok for me to PIMP you out to larry.
can I Get a cut, say 5% :)
Post by: larry104 on June 09, 2007, 05:44:02 am
Thanks for the link, Hillshy. That's exactly what I needed.
Post by: RabbitJockey on June 09, 2007, 07:47:43 am
yes you can have 5%, besides i need someone to start slapping ***es for me... my hand just can't take the abuse.
Post by: Hillshy on June 09, 2007, 12:41:18 pm
sweet glad to hear that!
batch slapping and 5% all in a dayz work my man :wink:
gotta go n pack my case,  on holly bobs in the morning..
my lil sister is getting married this week in Jersey (a wee island just of the uk coast)
c you in a week guys
hillshy
Post by: jtanguay on June 09, 2007, 02:53:06 pm
i just got back from andy2's place.  he just hooked me up with some insanely cool mods!!! hooked up my solid state fuel pump (there was a small leak when checking to see how much fuel was being pumped...  :shock:)
a little bit of tuning later (reduced fueling) 20 psi boost approx.  absolutely no smoke out of my tailpipe! i am now a happy man!  i hope to see some fuel mileage increases too!
i would have to say that andy2 is also a pimp! he works wonders with the starwheel adjustments!  with the right adjustment and increased boost, you can pretty much eliminate off boost smoke, and increase on boost fueling.
Post by: rallydiesel on June 09, 2007, 07:07:02 pm
So how much do you need to turn the starwheel bolt to see a change? Like a quarter of a turn or more like several full turns?
Post by: Benjamin on June 10, 2007, 03:03:30 am
it all depends on your settings, a guy ever told me when the LDA go down to deep the pin toyour LDA can break. (i think this only can happen when you remove the plactic ring)
i turned my about 80degrees and it was realy better.
if you do starwheel adjustments just take a paper and count the clicks you make, so you can always go back to stock settings
Greetz, Benjamin
Post by: RabbitJockey on June 10, 2007, 07:48:47 am
i mark mine with marker and just look at how many turns i do.  i think thats alot easier than counting clicks.
