Engine Specific Info and Questions => IDI Engine => Topic started by: subsonic on May 04, 2007, 08:23:55 am
Title: Franken glow plug/ control/ relay question
Post by: subsonic on May 04, 2007, 08:23:55 am
So with the 1.9 head going on it would make sense to use the 1.9 glowplugs. Duraterms I believe?  Anyone have a part number for these and the injector heat shields?  Always get a funny look when I ask for 1.9IDI parts.  " Don't you mean TDI?" Stateside thing :roll:  What issues will I run into with this switch?  Will I need to swap out the other parts as well? Relay, controler, larger fuse in the panel?  I am putting the parts list together so I can get this project rolling.
Anyone know a good place to get 1.9 injectors rebuilt?  I am a bit leary of having it done stateside as most guys have never delt with the 1.9IDI injector setup.  Going to put in the DNO SD261 nozzles.
Thanks, Jim
Post by: subsonic on May 06, 2007, 05:42:34 pm
Anyone?
Post by: 935racer on May 06, 2007, 08:26:02 pm
You don't need anything special besides the glowplugs, if you don't already have a fast glowplug relay get one of those. I think in the states you guys have some NA 1.9IDI's in mk3's I would bet the glowplugs are the same. But to be honest with you I can't tell any difference between using good bosch glowplugs made for 1.6's or 1.9's.
