Engine Specific Info and Questions => IDI Engine => Topic started by: scopefrfd on November 19, 2006, 07:17:11 am
Title: hybrid turbo setups
Post by: scopefrfd on November 19, 2006, 07:17:11 am
I have quite a few turbos laying around and I decided to go through them and rebuild what I have.   And some of the differences that I've noticed.
On the diesel side:
1.6td, t-3
volvo td t-3
1.9 kkk k03
audi kkk k-24
1.6td KKK k14
gas:
1.8t 20v KKK k03 150hp
1.8t 20v KKK k04 225hp
gas 8v turbo t-3 .42 a/r
audi 5000T k26
The volvo D24td turbo, although the a/r is the same as the vw units, the trims are larger.  The turbine and compressor wheels will not fit in the vw housings.  The wheels are much larger than the 1.6td units
The KKK K03 AAZ style 3-bolt, the gas KKK K03 has a much larger compressor wheel.
The gas t-3 turbo I have has the same a/r as the 1.6td, the turbine wheel is the same but it has larger compressor wheel.  It's actually a hair larger than the volvo td compressor wheel.
And the audi k26 has a much larger compressor wheel than the KKK K24.
Now, I was thinking of combining:
The KKK K03 diesel turbine with the audi K03 150hp gas compressor/housing.   It still should have the lighting fast spool up and a little more top end with the larger gas wheel.  Should be a nice turbo for a converted N/A 1.6 diesel or 1.6td, setup for max mileage
The 1.6td t-3, but swap in the compressor wheel/housing from the gas turbo t-3.  Again the compressor wheel is approx the same size as the volvo td.  A little slower spool up but more efficient under higher than stock boost levels.  May be a great turbo for 1.9 td's and tdi's or modded 1.6td's
The KKK k14, I'd like to get a k16 compressor side..the K24 nothing swaps over...I believe the audi k26 cold side should swap into a k24..that would make some serious boost with the right setup.
Wondering if anyone has already used any of these hybrids listed above and there findings.
Post by: entuzijast on November 19, 2006, 10:30:29 am
I was wondering about K14 and K24 hybrid, and you say that it isn't doable....I thought that while T2/T3 hybrid is possible, K14/K24 would also be possible...
Post by: scopefrfd on November 19, 2006, 10:48:08 am
the k14 and k24 have different shaft diameters..so I don't know how you could build a hybrid
Post by: andy2 on November 19, 2006, 11:05:37 am
I've made a hybrid k24/k14 (k24 turbine with k14 compressor).Definitely a waste of time, stick with the 1.6 T3 and it will work great up to 22-24 psi no problem.T3 over k24 any day.
Post by: scopefrfd on November 19, 2006, 11:15:50 am
I would imagine that setup would be counter productive, it think the k03 td turbine and gas k03 compressor would be great for an eco diesel
"I've made a hybrid k24/k14 (k24 turbine with k14 compressor).Definitely a waste of time, stick with the 1.6 T3 and it will work great up to 22-24 psi no problem.T3 over k24 any day."
Post by: deezul ryan on December 29, 2006, 07:12:33 pm
has anyone tried a k24/k26 combo?  k24 turbine with a k26 compressor?
i will try this soon after i get a rebuild kit.
Post by: andy2 on December 30, 2006, 08:25:49 am
Dr Diesel has ran that combo I can't remember the results of it though?
Post by: andysimpson on January 27, 2007, 11:43:58 am
Quote from: deezul ryan
Have you tryed this? I have a 24 and a 26 and am tempted to make a 24/26
Post by: scopefrfd on January 27, 2007, 03:48:34 pm
I'd love to see someone try a k24/k26 hybrid...especially on a tdi or 1.9td
Post by: aidan on January 28, 2007, 05:33:18 am
Are any parts between the K14 and the 1.8T K03 interchangeable? I have a 1.8T K03 sat in the garage doing nothing, and the K14 is on my GTD.
Maybe K14 turbine and turbine housing on the K03 compressor, compressor housing and centre section?
