Engine Specific Info and Questions => IDI Engine => Topic started by: psyte on October 31, 2006, 10:47:12 pm
since i bought my car (86 jetta 1.6L n/a diesel standard) the tach jumps all over the place and usualy hangs around 6 - 7000rpm's on the guage. someone told me this car gets its readings from the alternator, anyone know why its doing this? the red battery light stays on when i first fire it up and the tach is at 0, once i hit the gas the light goes off and the tach goes nuts.
Try another alternator..
The tach gets it's reading from the W terminal on the alternator. It's normal to have the rev the engine a bit to get the alternator charging, I wouldn't worry about that.
You might have a bad wire that's shorting out somewhere
My tach does not go anywhere near 7k
(http://img.photobucket.com/albums/v603/burnyourmoney/8c1cbf8c.jpg)
do you have a converted gas tach?
possible it's gas tach that somebody stuck in there? Does it say diesel on the tach like the one in the pic above?
Yep, sounds like a gas tach has been installed. It'll read many times the actual RPM if driven off the W terminal output:
- http://www.4crawler.com/Diesel/CheapTricks/Tachometer/index.shtml#OEMInstall
Gas tach in a diesel will look like this:
(http://www.4crawler.com/Diesel/CheapTricks/Tachometer/Images/tach_14.jpg)
Deleted
mine looks different than both of those. but mine deffinately doesnt say diesel on the tach anywhere so its possible it was converted. it looks alot more like the first pic posted by "burn_your_money" exept theres a shift indicator at the top(wich also doesnt work) and the temp and gas guage is below the tach. also theres no lights on the lower section of that little 10 LED cluster and its missing the temp light(wich is actualy in the middle of the temp guage instead) why would anyone want to swap out the diesel guages for a gas one?
Most diesel's did not come with a tach and for a factory look people will modify and swap in a gas cluster with a tach.
Could you get a picture of yours?
heres the pic
(http://i2.photobucket.com/albums/y12/sweetbox6t9/000_0231.jpg)[/img]
That's a mk2 gas cluster. It must have been converted, or possibly just plugged into the W-terminal with no modifications, which is why you are getting the weird readings. Did it ever work?
nope, not since i bought it. id really like to have a working tach, is it possible to find a diesel tach in a junk yard? or can i just buy an aftermarket tach for this car at a parts store?
Yes to all the above. Answers to how may be found on the web page I posted a link to earlier.
Actually, those instructions on the www.4crawler.com page do not work.
I'm surprised nobody has pointed you to the posts here on this forum by regcheesman before now.
Anyway, better late than never.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=3741
http://vwdiesel.net/phpBB/viewtopic.php?t=3096
Good luck.
Good luck.
Added those links to the above page under the tachometer modification section:
The other options still apply as well.
Not sure that's true. Have you performed those other options and tested them yourself?
In post 6 in the second thread I quoted above, when someone referred him to the gas-tach hacks on the 4crawler website, regcheeseman replied:
I was looking to do that to mine, and followed his instructions to the letter - they didn't work.
I reverse engineered the board and the suggested mods and there was no reason why they would ever work. I emailed the originator of the gasser tacho mod and received no reply.
So figured - do it myself (I'm an electronics design engineer)
Yes, I have used the optical tachometer kit described on the page and designed and built by myself, as well as having about 50 of those kits out in the field over the last 6 years (and countless folks who used the basic design for their own circuit):
- http://vwdieselparts.com/forum/viewtopic.php?t=5887
I also have heard of folks using the Dakota Digital convertor, which also requies a calibration step. My tach signal generator is designed to be 100% accurate out of the box, no calibration required.
What the poster was likely referring to as "didn't work" was that he was not able to follow the brief description of the gas tach recalibration procedure that I had a link to on my site. I am not the author of that article, nor have I tried it. Someone referred me to that writeup many years ago, and I obtained a copy to place on my page from the author, Mike Musick. He states that he has used those directions to modify 3 gas tachs.
on ebay now...
http://cgi.ebay.com/ebaymotors/Vw-diesel-1987-Volkswagen-instrument-cluster-tach_W0QQcmdZViewItemQQcategoryZ33711QQihZ018QQitemZ280045547483QQrdZ1QQsspagenameZWDVW
Auction ends tomorrow.
J.R.
SoCal
damn, i really want that tach, but the current bidder obviously wants it bad cause i got it up to 60 dollars US not includeing shipping. what do you guys figure this is worth? i want it so bad.
$150
