tomorow i look to my croma pump to confirm, Sebzero from the french section should also know this
this is my first post....and wondering if the peugeot pump I just bought off of ebay will be a good candidate for a tdi M?....its out of a 1995 peugeot 405 with a 1.9 tdi engine....dont have it in my hands yet...(its on the way from UK via DHL) but as soon as I do I'll post the part number....thanks....
Quotetomorow i look to my croma pump to confirm, Sebzero from the french section should also know this
My croma 1.9tdi (spare)pump: 0 460 414 058
Greetz, Benjamin
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 315 ADJUSTING PIN 1463103315 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 638 CAM PLATE 1466110638 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 336 TIMING-DEVICE PISTON 1463104336 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 33 2 1 464 619 628 COMPRESSION SPRING, 36,50 MM 1464619628 34 1 1 464 619 619 COMPRESSION SPRING, 36,70 MM 1464619619 34 1 1 464 619 627 COMPRESSION SPRING, 37,00 MM 1464619627 34 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 301 CLOSING COVER 1465530301 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 312 COVER PLATE 1461074312 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 2 1 468 334 471 HYDRAULIC HEAD 1468334471 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 FITTING 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 1 1 465 534 373 HOUSING COVER 1465534373 67 1 1 463 161 596 SHAFT 1463161596 68 1 1 460 200 333 SPACER RING 1460200333 69 1 1 461 900 517 CONTROL LEVER 1461900517 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 073 FULCRUM LEVER 1461907073 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 356 SHIM RING, 1,60 MM 1460100356 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 1 463 123 365 RETAINING PIN 1463123365 120 1 1 464 650 386 EXTENSION SPRING 1464650386 122 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 3 1 460 362 408 CONTROL VALVE 1460362408 135 1 1 463 456 303 HOLLOW BOLT 1463456303 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 1 410 407 004 PROTECTION SLEEVE 1410407004 142 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 460 410 308 DISTANCE PIECE 1460410308 202 1 1 460 500 307 SPRING SEAT 1460500307 203 1 1 460 023 306 WOODRUFF KEY 1460023306 205 1 1 464 616 656 COMPRESSION SPRING 1464616656 215 1 1 464 651 454 COILED SPRING 1464651454 220 1 1 464 477 302 BLADE TERMINAL 1464477302 228 1 1 463 314 306 FLANGE NUT 1463314306 230 1 1 461 021 355 SUPPORT PLATE 1461021355 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 245 2 1 463 456 340 HOLLOW BOLT 1463456340 246 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 2 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 1 461 900 519 CONTROL LEVER 1461900519 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 2 911 222 700 HOLLOW BOLT 2911222700 354 2 1 460 105 313 FLAT SEAL RING 1460105313 355 4 1 460 793 336 CONNECTING PIPE 1460793336 366 1 1 460 793 337 CONNECTING PIPE 1460793337 367 1 1 467 414 417 PRESSURE MODULATION VALVE 1467414417 381 1 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 016 308 INTERMEDIATE PLATE 1461016308 394 1 1 465 130 755 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130755 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 |
