Engine Specific Info and Questions => IDI Engine => Topic started by: DieselScout on December 04, 2025, 08:05:12 am
Title: 2.4L D24T Oil Pump OE Number interchangeability
Post by: DieselScout on December 04, 2025, 08:05:12 am
I believe my current pump may be the cause of the lower than ideal oil pressure.
So I am looking for a replacement oil pump for a D24T motor. (VW 6 cylinder used in a Volvo 240/740)
I found a NOS pump on Ebay with a part number of “069115109G,” that says it’s for the Audi 5000 l5.
Where-as the part number cast on the pumps that I have are “069115109."
Does the letter at the end signify anything,” such as a different capacity/pressure/flow rate?
Or should they all be interchangeable?
Title: Re: 2.4L D24T Oil Pump OE Number interchangeability
Post by: Dennis Froelich on December 04, 2025, 11:13:13 am
Here are the part numbers that I found for that exact engine...
069 115 105J
069 115 105Q
075 115 105A
VW Classic Parts has these. 069 115 105Q is a direct replacement. The oil pickup tube is nearly 36 inches long.
Post by: Michael Zill on March 25, 2026, 09:50:32 am
Hello what should i do I have a 069115109 in Brand new original and i dont know if i can put it in my 2.4 liter VW 6 zylinder Diesel does anyone know anything?  Please give me a Solution
Michael
Post by: w1004thw on April 09, 2026, 12:46:45 pm
If the eBay pump is truly an NOS 069115109G, it should physically fit and work on your D24T.
If you want absolute certainty, check the pressure relief spring spec or ask the seller if it’s the “same flow spec” as your original pump
