Engine Specific Info and Questions => IDI Engine => Topic started by: Buji88 on August 31, 2018, 07:48:51 am
Title: Size for fitting for turbo feed off oil filter bracket? (1.9 AAZ)
Post by: Buji88 on August 31, 2018, 07:48:51 am
Hi guys!
I searched, couldn't find my answer so I hope someone here will know. I'm putting a 1.9 AAZ in a Sidekick and I need to move the factory turbo feed line and run an AN line to get away from the exhaust. I know the turbo oil port is M12X1.5 which there are no issues there, does anyone know if the port directly off the oil filter bracket is the same size (I will be removing the stock fitting)? I looked and it seems to be the same size. Thanks, everyone! Also, any thoughts on -4AN vs. -6AN for the feed line sizing? I'm thinking -4AN should be good.
Title: Re: Size for fitting for turbo feed off oil filter bracket? (1.9 AAZ)
Post by: ORCoaster on August 31, 2018, 07:50:31 pm
I have those fittings someplace in my turbo addon project place.  I will measure and get back to you later on that.
As for feed line 4AN should be fine.  Just be sure to make the oil drain a larger size as that is only operating under the influence of gravity and bigger is better there.
Post by: Buji88 on September 09, 2018, 11:21:07 am
For reference both sides are M12-1.5! Thanks guys!
