Engine Specific Info and Questions => IDI Engine => Topic started by: Bigmick77380 on August 20, 2018, 10:03:23 am
Hi guy's !
Somebody already try to make an adaptator to fit a t25 turbo flange to a 1z exhaust manifold ?
Or do you know a good exhaust manifold who look like the one of the 1z ? (with the turbo under the manifold).
I will put a Hx27w with a 5cm² housing on my AAZ, and i need a exhaust manifold with turbo under it because i want to put an AWIC juste behind the intake manifold (of a PD130), so i will have an super short piping in 2.5".
Thanks :D
Search for 8v manifolds on eBay. There's ones that go straight out and ones that go "up" but you could pretty easily flip it and have the mount facing down
Check out the individual pictures on this ad on CL. Is that the needed trapezoidal flange you seek?
https://seattle.craigslist.org/kit/pts/d/vw-16-diesel-motors-turbo-and/6669263268.html
sounds like he wants a t25 manifold to mount a holset with a bottom outlet like that pic
Thanks for the answer
Yes i want something like this :
http://www.eurotrashmotorsports.com/wp-content/uploads/2016/09/IMG_8101-570x427.jpg
The thing is that i want the cheapest manifold, and the less expensive that i found cost 160€ (185$)
So befor i buy it, i want to know if i can found something cheaper :)
Also i looking for a pump preparator around france, i want a pump who work great with the hx27, and i don't think mine was the good one for this....
