Engine Specific Info and Questions => mTDI Mechanical TDI Conversions => Topic started by: damac on June 01, 2017, 12:03:23 pm
Title: what is the minimum exhaust pipe size i need?
Post by: damac on June 01, 2017, 12:03:23 pm
i got a golf mk2 chasis somebody took some time to swap aaz, cutoff downpipe, put on flex hose and used other bits to complete exhaust.  i dont think the golf diesel chasis came with turbos and has tiny exhaust pieces.  last i experimented with this on a vw truck and egts went crazy high during hill pulls.  took all that stuff off and it went down allot so i assume it was restricting.
i want to put an alh in this chasis with a rover pump and assumed i would make a new exhaust but figured why do extra work if not needed and i will measure what i got.  i assume if i take the exhaust manifold, etc. off the aaz and slapped it on the alh it would be at a similar location?
Title: Re: what is the minimum exhaust pipe size i need?
Post by: vanbcguy on June 01, 2017, 11:08:46 pm
2" would be the smallest I'd even consider. 2.5" would be my recommendation...
Post by: ORCoaster on June 02, 2017, 08:27:05 pm
2.25 would be my minimum.
