Engine Specific Info and Questions => IDI Engine => Topic started by: dave friday on June 24, 2015, 01:46:35 am
Hi all,anyone got a wiring diagram [circuit diagram] for the above that they could pm me?
Ta.
Nothing that makes sense, but what wiring issues are to trying to sort out? As I have my dead 1991 GTD outside.:) My guess is your Turbo coolant pump not running?
Hi Smutts,I have a sb that I'm getting ready to replace the very poorly jx,I want to know if the sender on the water pipe on the Middle of the head is connected to the water temperature gauge and the glow plug system,the other sender I guess is for the aux water pump .
Ta.
Okay, here goes, the two temp senders on the water outlet elbow in the front middle of the head, both are identical, one runs the temperature gauge, the other goes to the glow plug timer relay. The electrical turbo coolant pump is switched from a brass temperature switch on top of the turbo. ;)
Ta ever so much,i didn't think to look there!!
