Engine Specific Info and Questions => IDI Engine => Topic started by: dave friday on June 12, 2015, 01:31:26 am
Title: "SB" engine advice
Post by: dave friday on June 12, 2015, 01:31:26 am
Morning all,yes advice on the above please [spigot bearing,sump etc]
Spain has high hot winds and long hills...a bad combination for a heavy brick shaped van!
Ta.
Title: Re: "SB" engine advice
Post by: Rock3tman on June 12, 2015, 11:22:22 am
I'd install an exhaust gas temperature pyrometer and the best new pre-cups you can get in a "SB" 1.6 syncro vanagon - -  no matter what; as that engine is going to be under a LOT of thermal stress.
For pre-cup discussion see: http://www.vwdiesel.net/forum/index.php/topic,33184.0.html
my $.02
Post by: dave friday on June 12, 2015, 12:35:53 pm
Thanks,At the mo' the van has a "JX"engine with a front mounted oil cooler,ETG pre-turbo [ seen 800deg c !],oil pressure n temp and a boost gauge [ .6bar].
The plan is to fit the "SB" engine with its water cooled turbo and intercooler..
