Engine Specific Info and Questions => IDI Engine => Topic started by: jaed_43725 on July 06, 2013, 07:38:25 pm
Title: Down Pipe (dp) gasket.
Post by: jaed_43725 on July 06, 2013, 07:38:25 pm
What is the part number either factory or from a manufacturer for the turbo to dp gasket? I have read of people on here using a copper substance in a tube to also make a gasket. Is that a better way to go? Any help is appreciated.
Title: Re: Down Pipe (dp) gasket.
Post by: akrallysport on July 06, 2013, 08:47:11 pm
What turbo?
Post by: jaed_43725 on July 07, 2013, 06:15:33 am
K14
Post by: bbob203 on July 07, 2013, 06:26:47 am
not all turbos had the gasket.
Post by: jaed_43725 on July 07, 2013, 06:52:02 am
So would a nice clean surface work then? Or is it best to have a gasket or make a gasket?
Post by: Gizmoman on July 07, 2013, 08:16:51 am
I had a gasket on mine when I took it apart. After a similar discussion here, it seems many don't use one, so I didn't either.
I think Proth sells them but if your surfaces are flat, you should be OK.
I used high-temp silicone on mine but it's not running yet so I can't say if it will work.
