Engine Specific Info and Questions => IDI Engine => Topic started by: TylerDurden on November 13, 2012, 02:58:32 pm
Anyone got a line on the o-rings for the newer style vacuum pump? (AutohausAZ & PartsPlace don't seem to stock em.)
I used a distributor o-ring (my assumption was that it's the same) ???
Which one? the one inside the gear is dealer, the one one the pump cover is the same as the IM shaft seal carrier o ring, and the one that seals to the block I think is dealer or the same as the distributer if it worked for the guy above.
Have you ever heard of an industrial hydraulic supply store?
.....there you go......
Thanks for the replies.
Autohaus has the larger "distributor oil seal". Looks like the dealer for the inner ring.
Dealer wanted $6 for the vac pump to block o-ring what a rip off! I looked in my box of o-rings and found that the one for the coolant flange on the cyl head fits perfectly.
Sweet. Thanks!
Followup:
The water flange o-ring fits nicely, on the flange/block area. P/N 037 121 687
The shaft seal from dealer: P/N 068 145 117 B
(The distributor o-ring was too small.)
The distributor o-ring is the correct VW part. 068145119.
Thanks, I got the wrong distributor o-ring. (026 905 261)
Anyone know anything about the bushing
Bushing was dealer only and NLA.
Seriously, though, if you can find an industrial hardware store in your area, it's worth an occasional trip there. The one near me has a great supply of metric fasteners, miscellaneous hose, rubber parts and o-rings that start at maybe 1/16" diameter up to what have to be several meters in circumference.
Ja, no doubt.
It would be nice to find the shaft seal from a 3rd party. $6 for that little dude is steep, IMO.
As an aside:
I spun the IM shaft CCW with a drill, to pump some oil around. Nice to see the air getting purged out the lifter bores. It's also kind of surprising how loud the vacuum pump is when you can hear it through the open oil returns in the head: POP POP POP POP... It seems like a fair amount of oil gets pushed through, while pushing out the vanes.
I should qualify...my dealer said NLA, so they still could be, but for sure custom made or dealer item only.
What bushing are you talking about?
The bushings in the block that the oil pump passes through to drive the vac pump...that is what I was talking anyhow.
I've gotten those not too long ago. They appear to still be available from VW and I imagine they will be for a while yet as they are the same in the AAZ and AHU/1Z. 056103541. I think if your dealer said they were NLA then he's just a lazy sod.
yeah alot of parts guys have a severe case of laziness, anytime you say a year before 1993 its nla with out them even looking, our local dealer has a good parts guy, u can always call any parts guy all around the country. i've done that before i was trying to get the unlock code for my gfs 90 cabriolet radio some dealers just wont do it and some want to charge, i just kept calling around till i got someone to do it.
Any good way to take those vacuum pumps apart?
(I had the top off one but that was as far as I went.)
http://forums.vwvortex.com/showthread.php?5129625-Diesel-Vacuum-pump-rotary-vane-type
