Engine Specific Info and Questions => IDI Engine => Topic started by: iheartbeets on October 21, 2012, 08:16:25 pm
Title: OH NO! Valves, meet pistons
Post by: iheartbeets on October 21, 2012, 08:16:25 pm
So, the time had come to pull my IP.  It was leaking bad.  I replaced the timing belt 40,000 miles ago.  It was getting wet and I was leaving puddles.  Hard to start in the morning, etc.  Luckily, I had a pump that came from a known running vehicle.  My uncle and I got everything swapped out.  We fired it up and it sounded like the problem that others have had (180 out).  I have all the correct tools for the job so we locked the cam again, lined up flywheel, inserted pin into the injection pump hole.  In our haste, we forgot to take the IP lock pin out and it jumped time.........you know what happened next :'(
So, I made a stupid rookie move and now I'm moving to plan B.  I'm sending the IP off to Giles in the morning.  I have a good running Eco engine.  I have a complete engine reseal kit.  I have new injectors and plugs.  My plan was to build this thing over the winter but now my time line just got pushed forward a bunch.  I'm asking you folks what all I should replace while I have the engine out.  I figure:
-clutch, pressure plate
-engine mounts
I guess I am still unsure as to how to mount the pump properly also.  With the cam lock in, IP pin locked in the proper hole and the flywheel at TDC with both cam lobes on #1 up, how do you know when the IP is injecting fuel into #1?  Are those the only things necessary? Does the IP inject fuel to all 4 injectors per revolution or one injector per revolution? ::)  I know, it's probably a silly question to you vets.  Any help is greatly appreciated as always.
Title: Re: OH NO! Valves, meet pistons
Post by: libbydiesel on October 21, 2012, 08:37:46 pm
If your sprocket has just one hole that fits the pin then when the crank is at TDC, camlock is in and pump pin is in it is timed correctly.  If your sprocket has two holes that size 180° apart, then you have to make sure the pin is in the hole that corresponds to a mark on the inside of the sprocket lining up with top centerline of the pump.  The injection pump injects fuel to each cylinder in turn during one rotation of it's sprocket.  The inj pump sprocket (and cam) spins at 1/2 crank speed so only injects fuel to two of the cylinders per crank rotation.
Post by: iheartbeets on October 21, 2012, 08:48:19 pm
Thank you libby!  Then the engine was in time.  The pump was just poop.  All the sprockets that I have only have one hole that fits the pin and also allows the marks to align properly.  Anything I should grab for my swap save what I already have?  As soon as I heard that sound, I knew what had happened and my heart sank.  I feel like I am responsible for the death of a perfectly tired 1.6 NA :'(
On a lighter note, I'm ready to attack this and get the turbo in.
Post by: CRSMP5 on October 21, 2012, 09:08:18 pm
sorry... im a dick... but... what happened to turn it over 2x by hand before hitting the key?? rule on ANY engine you screw with cam/crank timming is to turn it over by hand... if you lacked that info.. you learned now i hope..
Post by: 745 turbogreasel on October 21, 2012, 09:17:17 pm
Yup, I learned the same lesson the same way.  Now I'm pretty anal about the hand rotations.
It is still possible the pump was out of time, but it would be an internal assembly mistake and without the old style pulley, you'd have no way of fixing it without pulling the pump apart.
At cranking speed, there may not be much damage, valves and lifters should be checked though.
Post by: iheartbeets on October 21, 2012, 09:19:58 pm
You're right.  I deserve whatever I get by sharing my story.  We DID turn it over by hand the first time.  I was very explicit about all the interweb knowledge I've garnered from folks like you over the years.  It's my failure and I have to live with it.  My uncle, for the record, is a Chevy guy.  Not a backwoods WT idiot by ANY means but he is out of his element when it comes to working on my car.  He just happens to like wrenching and has a lift at his place.  I have to bring metric tools with me.
So, back to my other question, what should be ready to go when you swap engines?
Post by: iheartbeets on October 21, 2012, 09:25:43 pm
I was able to retime and fire it back up.  It runs, just like ragged dog poo.  I heard the smack of interference.  I get barely any response when I give it fuel.  I got barely any response before the accident.  Even after timing it with the dial indicator.  I think this is an omen.  Put the dang turbo engine in, have giles rebuild the pump, put the GTD intercooler on and be done.
Post by: TylerDurden on October 22, 2012, 04:26:43 am
IIRC, You can verify the pump is not 180 out internally, by slacking the #1 hardline and turning the engine by using the front wheel off the ground. You should see a burp of fuel each time the IP gets to the timing mark.
I lift the passenger side wheel and put the car in 5th gear to get the best mechanical advantage.
Post by: theman53 on October 22, 2012, 05:43:00 am
I would do the water pump, t stat, and starter bushing along with what you have listed. If you live somewhere cold when the engine is out it is easy to put in a block heater. Also, the oil pan gasket is easy to do with the engine out, and if you have it that far you should replace the front and rear mains.
Now when turning by hand the next thing to do is remember to not leave the ratchet on before starting it with the key.
Post by: libbydiesel on October 22, 2012, 07:01:40 am
Check the intermediate shaft bearings.
Post by: R.O.R-2.0 on October 22, 2012, 10:40:31 am
ive left ratchets on the crank pulley before.. as long as you have the ratchet set the right direction, it will just make a horrible racket, and come off..
Post by: CarlosA on October 22, 2012, 12:21:01 pm
Ive been using this tool (http://www.fastenal.com/web/products/detail.ex?sku=0245871) to rotate the engine anytime I do any timing, etc. Works very well from above the engine and is plenty stout enough for the compression of these engines.
(http://www.milzymotorsports.com/miva/graphics/00000001/serp_tool_1_large.JPG)
Post by: R.O.R-2.0 on October 22, 2012, 12:37:08 pm
these engines are no harder to turn over than their 1.8 gasser counterparts..
its not like you are turning them over FAST by hand..
Post by: theman53 on October 22, 2012, 06:34:39 pm
I know a guy personally that left a rachet on a TDI and it bent a rod. Now a TDI rod is probably 1/2 the strength of our 1.6, but still I wouldn't want it to happen too often.
Good call on the IM bearings if they need replaced do that too.
Post by: iheartbeets on October 22, 2012, 06:37:34 pm
Thanks for all the replies. Got the pump sent off this morning. I'll post some pics of the engine as I clean it up. Pics are always fun.
Post by: hillfolk'r on October 22, 2012, 08:06:53 pm
 ItsHydro lifters right? Check the lifters carefully,i had a similar situation happen to me,and the lifters all had these nice spider tracks coming from the center of the puck outwards,no lift no power :)
you could get lucky and thats your problem
Oh,btw i drove mine for 3 weeks with the lifters like that before i parked it and tore it down
yea its always fun when ya leave the wrench on the crank bolt.
i saw a dude hole a radiator on a big truck once doin that.
now i always make a joke and say take the wrench off the crank and look for all locks and tools sitting near moving parts
Post by: alexgingles on October 23, 2012, 06:37:00 am
ouch.  When am I supposed to build this downpipe for ya?  I guess pretty soon 'eh?  If I were you, I would drill a port for an egt probe if you havent already.  I know some folks drill it with everything mounted.. I would take the manifold off and do it that way.  It's a lot easier to do this job with the engine out.  The Giles pump and your newly added lead foot will definitely raise your egt's.
Post by: 92EcoDiesel Jetta on October 23, 2012, 07:20:40 am
Hmmm, why is a TDI rod 1/2 the strength of the 1.6?  ???
Post by: theman53 on October 23, 2012, 07:27:52 am
If you ever see one you will understand. My guess is they use 1/2 the forging to make them just by the looks of it.
Post by: iheartbeets on October 23, 2012, 07:33:20 am
Hey Alex,
I still have all that 3" stainless tube.  About 24' of it.  I could drive it down to you but there's no one around that can bend the stuff (that I know of).  I did drill a hole in the manifold for the EGT probe.  Figured it's a good idea to keep an eye on.  Also got a boost gauge and mounted them both in the A pillar with this:(http://www.vwcraft.com/wp-content/uploads/2010/02/MK2-A-pillar-Pod-1-210x300.jpg)
Post by: alexgingles on October 23, 2012, 07:50:18 am
U might have to buy pre-bent u bends off eBay.  2 u bends required for the dp.  I think there is a place in Topeka that does mandrel bending.  They'll sell u bends too.  If you're interested I'll get their contact info for ya.
Post by: iheartbeets on October 23, 2012, 08:29:49 pm
Ok. I think I want to get through this engine swap first. Kind of on a tight timeline. I got the longblock TD tore down. I'll be getting it all cleaned and prepped and all the new stuff swapped on it. I'll still give you the tube I promised though. I could bring it down this weekend.
Post by: iheartbeets on November 19, 2012, 12:18:59 pm
(http://i88.photobucket.com/albums/k165/iheartbeets/IMG_2089.jpg)
(http://i88.photobucket.com/albums/k165/iheartbeets/IMG_2088.jpg)
(http://i88.photobucket.com/albums/k165/iheartbeets/IMG_2079.jpg)
(http://i88.photobucket.com/albums/k165/iheartbeets/IMG_2092.jpg)
Post by: audilvr on November 19, 2012, 02:18:11 pm
if it makes you feel any better i put a na engine in my golf when i got it, drove it for 50k. pump failed spiking the rpm. replaced engine with td. made it 10 km on a test drive, crank broke. towed it to my dad's and didn't look at it for four months. now i have another td in it working ok, but i'm rebuilding a gtd engine so i know what i have next time.
Post by: R.O.R-2.0 on November 20, 2012, 11:54:15 am
the CRANK broke?!?!?!
pics or it never happened..
these cranks will crush rods all day and not even bend..
how on earth did you get one to BREAK?!
please tell me you took pics, or still have the engine, and are able to take pics?!
Post by: slowcaddydan on November 20, 2012, 06:42:12 pm
crank broke.
i'm willing to guess that the sprocket key gave way?
Post by: slowcaddydan on November 20, 2012, 06:43:30 pm
what's up with your alternator setup? is it an "ABF" setup?
Post by: burn_your_money on November 20, 2012, 06:54:58 pm
Seriously. I want to see pics! Sorry about your luck though...
Post by: Rock3tman on November 20, 2012, 08:57:09 pm
It looks like the alternator/serpentine belt setup is from a non-a/c AFN...see photo attached of my setup
Post by: audilvr on November 25, 2012, 06:22:07 pm
the keyway broke. i haven't taken it apart yet but the bottom pulley doesn't turn with the crank bolt.
Post by: theman53 on November 25, 2012, 06:27:33 pm
machine it for a AHU D sprocket...if need be weld it and have it machined for the D sprocket.
Post by: audilvr on November 25, 2012, 07:00:13 pm
i have another crank and head for it, but no need to build it now. it would have been great to get more than 10k out of it though.
Post by: iheartbeets on January 31, 2013, 12:51:29 pm
I did this AND added the clutched pulley.  I have a spare clutched pulley if anyone needs one, BTW.
