Engine Specific Info and Questions => IDI Engine => Topic started by: ein bora on September 21, 2012, 11:36:40 am
I"m looking to buy a serpentine belt for my azz, one without air conditioning. When searching for a non a/c belt - I'm finding belts of all different lengths? As I don't have an old belt to measure off of, would anybody know the right length that I will need.
Thanks.
I beleive its 1045? somebody correct me if im wrong.
No you are right - did some more digging and the consensus is 21.36 x 1045
Thanks much!
i believe i had to run a 1038 or something..
lemme go run up and check..
ive got a 1040mm belt on my car..
it says this belt is more commonly used on 1984 ford tempo, and mercury topaz with a/c.. and 1990 taurus w/ 1.9L
i had a 1054mm belt at first, and it was just a touch too long..
so, a 1045mm belt should be just about right..
Pardon the question, but didn't you have a similar thread you made or posted in a month or two ago about exactly this topic?
OT, I think you said 1035-1038 or around that, as 1045+ got too close to the water pump pulley.
yea, we went over all of this a couple months back..
the OP doesnt know how to use the search function, because there was alot of discussion about it!
http://www.vwdiesel.net/forum/index.php?topic=31119.0 (http://www.vwdiesel.net/forum/index.php?topic=31119.0)
